Missing Battery - adapting replacement
batterypackguy
Dec 3, 2021
Hello, thanks for having this awaesome forum.
What do you all think about using a 7.4vdc nikon battery pack to power this old robotic programming toy (2017)?
They no longer make the toy or the replacement battery.
batterypack.jpg Is there a way to adapt the contacts on the battery to the male receptacle on the toy?
14,317
Not as easy as you may think. The toy has 4 contacts, the battery has 3. So one will have to find how to connnect these, if possible at all. Impossible to say without having a clear definition of the 4 pins' function (be it a document or a schematic).
Martaine2005
May 12, 2015
5,318
It is possible with a little investigation.
But it depends if you keep it simple and charge the Nikon battery externally on its original charger.
Or modify the toy with an appropriate DC jack that can connect to the Nikon charger.
Alternatively, you could crack open the toys battery and replace the cells.
I’d try replacing the cells first.
If it doesn’t need to be battery operated , connect a DC adapter directly.
Martin
batterypackguy
Dec 3, 2021
Apologies for digging up an old thread, but it was still relevant.
Great suggestion on replacing the dead cells. However, I do not have the original case.
Amazon has a few 7.4v DC batteries (that's the rating on the robot case), but how the heck would you connect it to the robot? Could I crack the case and splice it together?
For example an RC battery with two connectors. One that connects to the RC and one that goes to the battery charger. Splice the battery cable that has the RC frame connector to the inside of the robot CPU case pictured above?
