missing some basic theory
findhelporbust
Oct 14, 2005
10
i know when you put resistors in parrallel they lower in value, but is it because of voltage or current, (or is it both) going in circles, could use some help.
(beginer electronics dude here)
audioguru2
Apr 6, 2004
12,022
Hi New Dude,
Neither voltage nor current goes in circles in a parallel circuit.
In your schematic, both resistors have the same voltage. The current in each one is determined by Ohm's Law (I= E/R). Their resistance in parallel Rp is also determined by Ohm's Law when you add their current into It (Rp= E/It).
If both paralleled resistors have the same value, their parallel resistance is half of one of them.
3 equal resistors in parallel = 1/3 of one of them.
4 equal resistors in parallel = 1/4 of one of them.
etc.
Just remember that resistors in parallel increases the current because thier value is approaching a short circuit that causes a very high current. ;D
prateeksikka
Jun 19, 2004
736
just as 2 people sitting together in a restaurant have more demand for food than a single person,similarly 2 resistors in parallel extract more current from supply and thus effective resistance is lowered.
Imagine what 100 people will eat!(case of a short circuit!!)
;D
prateeksikka
Jun 19, 2004
736
an when the food is same ,the one who is more hungry will eat up most of it.
the same is the case with a series circuit.
the lower resistance draws more current froma fixed power supply.
MP1
Dec 7, 2003
3,397
Here is a nice tutorial on series and parallel resistors that is not related to food:
http://schools.matter.org.uk/Content/Resistors/Default.htm
Hope it helps.
MP
V8meathead
Apr 28, 2005
64
Once you find the total current I(p).  And you want to find the current going through one of the two resistors.  Take... I(R1) = [R2/(R2+R1)]*I(p)  or I(R2) = [R1/(R2+R1)]*I(p).  These are called a current divider equations.
bhargava
Nov 28, 2005
38
Here i would like to put in some apt analogy than Food.
Electrons take lesser time to travel throgh lesser resistances like we do in lesser conjusted roads.
So more current flows through lesser resistances as current is rate of flow of electrons.
If we connect two resistors in parallel would be similar as 2 parallel conjusted roads and the total no of electrons flowing through will be sum of electrons flowing through both the resistors.
hence effective current increases for the same P.D
since R=V/I
the resistance decreases
