Need to power case cooling fans with 120v outlet
TheloniousMink
Sep 7, 2013
3
I need a schematic for a small electrical project. I want to hook up two computer case cooling fans to one standard 120v plug. That’s two fans into one standard 120v outlet.
The fan model is CoolerMaster 120-SI2, which has a 3-pin molex wiring harness. Red wire: 12V. Black wire: 0V (ground). Yellow wire: RPM sensor. Here are the fan’s specs:
Voltage: 12VDC.
Current (Ampere): 0.15 A±10%.
Input (Watt): 1.80W±10%.
Can anyone give me a safe way to wire this up? Without building a new wiring, I would need to buy a 3-pin to 4-pin adapter and an AC power supply for each fan. This is unacceptable because of space and budget limitations. Can anyone help? Thanks!
14,480
hi
welcome to the forums
I assume you are wanting to use them fans for a non computer related project ?
you could run them both off a single 120VAC to 12V DC 500mA plugpack
they will just be connected in parallel across the 2 wires out of the plugpack
You wont be using the RPM sensor lead
TheloniousMink
Sep 7, 2013
3
Just splice it?
Dave,
Thanks for your response. Can I simply splice the plugpack wires to both fans' wires?
TheloniousMink
Sep 7, 2013
3
Dave,
That works great when I'm powering one fan, but if I hook up two or more, nothing happens. I need to power two (or possibly four) fans from one outlet.
