NX8E master user fault
proguard
Recently i install a Caddx NX8E-GR. Everything was ok except the basic!
The user #1 (master) does not have access to change his own code or to
programm even other users. That means that in a brand new control
panel, the user (#1 i believe) with code number 1234 by default isn't
the master! The installtion area doesn't have (untill now) phone line
so i cannot give master previledges by download via DL900.
Does anyone has any idea?!?! I'm trying [*] [8] [1234] and the ready
light did not flash....
Thanks in advance
Spyros Kintzonides
Thessaloniki - Greece
proguard
I have tried also [*] [5] [1234] but nothing happened... i don't know
what...
anyway, i believe i must wait for the telco to connect the line in
order to make a download...
Ο/Η diver έγÏαψε:
try *5 1234
Thanks in advance
Spyros Kintzonides
Jim Rojas
By default the master code is not changeable.
You have to go into dealer programming and turn that feature off. I am not
sure of the program location, but it is a check box in the download
software.
Jim Rojas
Cam
what...
Ο/Η diver έγÏαψε:
try *5 1234
Thanks in advance
Spyros Kintzonides
it's *5 1234 usernumber newcode
or *5 1234 01 ????
plug
Cam said:
what...
?/? diver ??????:
try *5 1234
Thanks in advance
Spyros Kintzonides
or *5 1234 01 ????
don't forget # to exit when done.:)
ABLE_1
Yo Spyros,
*8 is for installer level programming.
1234 is the Default Master User Code
*5 is for changing codes need Master User Code.
9713 is the Default Installer Code
They will not always intermix.
Do the following first. * 8 9 7 1 3 0 # 9 1 0 # {EXIT} {EXIT}
This will Default the panel.
Then to change master code * 5 1 2 3 4 0 0 1 (new master code)
# to exit
After that read the Installation Manual.
Good luck,
Les
proguard
I' ve done this also! I default the panel and again the code 1234
cannot be changed!
I type *5 1234 and the ready light didn't flash in order to give me
access to type the user number (i.e. 001) i would like to change... For
me it's mystery... It isn't the first time i'm deal with Caddx. I have
install plenty of NX4 and NX8... I think i must wait for the telco in
order to make a download to see what happened...
Ο/Η ABLE_1 έγÏαψε:
Yo Spyros,
# to exit
Good luck,
Les
Thanks in advance
Spyros Kintzonides
Rich
Thats why I use a laoptop and a cable. Whe I set them up I dont have to
rember numbers.
plug
must not be a master arm/disarm code then.
cannot be changed!
?/? ABLE_1 ??????:
Yo Spyros,
{EXIT}
# to exit
Good luck,
Les
Thanks in advance
Spyros Kintzonides
plug
have you tried 123456 incase its set for 6 digit code?
cannot be changed!
?/? ABLE_1 ??????:
Yo Spyros,
{EXIT}
# to exit
Good luck,
Les
Thanks in advance
Spyros Kintzonides
proguard
Also i tried 123456.. nothing happened again. The dealer code is ok. NP
with this. I have also change it and programm all the parameters of the
panel (and 4 digit code also). I dont know what to say about this....
Mystery! :) btw how can i connect my lap with nx8 without phone line?
Doug L
Does the code arm/disarm the panel?
Can you use the code to set the time & date?
Is the system partitioned ?
Does the following paragraph lifted from the installation manual apply?
NOTE: Any master arm/disarm code can add or change a user code if the master
code has access to the same partitions as the code being added/changed.
Consequently, when programming the user codes for a partitioned system,
leave at least one code (can be "go to program code" if enabled in location
43) access to all partitions or you will not be able to add new users. If
you desire the end user to be able to add new codes, you must remove the
partition authority from all blank codes.
Doug L
cannot be changed!
?/? ABLE_1 ??????:
Yo Spyros,
{EXIT}
# to exit
Good luck,
Les
Thanks in advance
Spyros Kintzonides
Sean Sokoly
get a NX586 Serial interface has the 3 wires that connect to the keypad
connections. There is supposed to be a USB version, I dont know if it is
out yet. You may want to check on that with GE tech support.
Mark Leuck
You have installed plenty of these and you can't figure out how to change
the master code???
cannot be changed!
?/? ABLE_1 ??????:
Yo Spyros,
# to exit
Good luck,
Les
Thanks in advance
Spyros Kintzonides
F
Frank Olson
the master code???
Every once in a while we have to rely on the helpful assistance of a
"programming guru". Some of us (like Tom for instance) have a special
"hot line" to your desk (I think the "bat phone" is flashing even now). :)
EJ
Hello mr Spyros ,
Have You put in your country code by set up ? ( NX 8 V2 )
* 8 9713 0 # 213 # X * # ( where X is your country code for spec.
settings ) then exit , exit.
You wil need to progranm the system again.
also try to set the time ? , thats also not working when your country code
is on factory set ( zero )
greets
S. Smith
DL900 spoils installers. As a matter of principle I make each of my
team learn the keypad way first and then give them the "easy" way. A
company that relies on downloading panels for programming breeds
incompetent installers good for only pulling wire.
If you haven't already called it up and fixed the problem, it looks
like the panel might have local programming locked out. Defaulting
gives a triple beep but so does an error.
Mark Leuck
WELL SAID!
