Op-amp or trans-impedance amplifier
zhiling0229
Apr 17, 2006
10
Hi guys,
I'm a newbie. I'm working on an amplifier for my photodiode project.
I was wondering which has better performance a general purpose op-amp with a feedback loop or a trans-impedance amplifier or is there a much better way to amplify the current?
I'm open to any suggestions. Thanks
zhiling0229
Apr 17, 2006
10
Thanks audio guru. But it looks kind of complex.  ;D
I will be using a UV photodiode which the wavelength is from 200nm to 320nm therefore the frequency will be in THz. I don't think i can filter it using the circuit.
Here are the two circuits that I plan to used circuit 1 is using a general op-amp and second one is using a transimpedance amplifier. both will require to produce output in the range of 0 to 2 V(max) and the photodiode will produce a maximum of 11.47uA.
Please comment on the circuit. Thanks
audioguru2
Apr 6, 2004
12,026
I can't read the frequency. Are you modulating the IR beam and need to filter it? A 741 opamp doesn't work very well above 9kHz, use a newer opamp with a much higher frequency response.
zhiling0229
Apr 17, 2006
10
hi audio guru,
I am not performing any modulation but I will be using my operational amplifier as a current to voltage converter. converting a maximum of 11.4 uA to a maximum of 2V.
Do you any operational amplifier that requires a maximum of
zhiling0229
Apr 17, 2006
10
Thanks Audio Guru,
I think I have resolve part of the problem already.
I'm posting a new problem in the community board hope you can help out.
