tadgesualdo
- Dec 21, 2005
- 23
- Joined
- Dec 21, 2005
- Messages
- 23
Well for the last several months I have been reading everything on the net, and in some books about opamps.
I haven't heard any difference, but an inverting opamp doesn't have any (well, hardly any) common-mode voltage swing at its inputs, while a non-inverting opamp has the entire input voltage swing at both inputs. The inputs are slightly non-linear so slightly more distortion is produced in a non-inverting opamp circuit.tadgesualdo said:I don't know the reasons why, but inverting inputs sound better to me than non-inverting.
I haven't heard any difference. If the feedback or if the load capacitance are not too high for the opamp then the distortion is 100 to 1000 times lower than I can hear. In the article you posted they show a standard method of reducing the effect of too much load capacitance, which is caused by a shielded audio cable at the output. Maybe you are reducing the opamp's feedback instead to reduce the effect of too much load capacitance.Also each opamp seems to have its own sweet spot for feedback settings.
Currently I have an idea of attempting to use positive local feedback on two opamp stages, and global negative on both of them together.
Could you expand on the reasons for this? What capacitor values do you use? What benefits does this have with the opamps performance?My trick besides the above-mentioned output resistor to isolate load capacitance, is adding supply bypass capacitors which are are important for opamps in audio circuits.
R3, R4, R9, R10, were inserted in this design based on the design notes below, see the subtitle "noise gain manipulation".
Nobody can hear frequencies as high as radio waves.tadgesualdo said:I can say I know what I prefer, and the difference seems to be in the high frequency extention.
Like I and the article said.The first run through with the bleed resistors did sound noisier
I will adjust the input coupling cap to be larger in the final design when I start using them, for now the 1uf will just be there to remind me.
