Active8
- Jan 1, 1970
- 0
Bondo is a common tool in the furniture restoration trade. It sands,
it stains, and can even look pretty good if it isn't up in your face.
Not strong enough for Jim's app. I't great for cosmetic repairs.
I think I'd suggest getting some Tuffnel rod. Drilling this 1/4", andJim Thompson said:Subject: Bookcase with Shelves supported by brass pins into 1/4"
holes drilled in side walls of bookcase body (oak plywood).
Problem: Cleaning lady stands on edge of a low shelf to reach up to
dust top shelves and rips out two pins, gouging out the drilled holes
I guess I can fill the holes and re-drill, but I was wondering if
there doesn't exist an over-size insert with a 1/4" hole in it?
Anyone have experience in this area? My Googling only produces how to
do it first time out, not how to repair.
What hole? Just embed the shelf support in the filler. What's with all
this sanding and drilling crap.
Hehe- the price he pays for going with the low bidder![]()
ROFL.
She will burn
the house down next...
or use the toilet brush on the sink fixtures or...
and cutting disks, the depth of the original hole. Then drill new
blind holes the size of the Tuffnel rod, and epoxy the disks into
the holes.
Active8 said:SureIf you plan to never need to raise or lower the pins - this
gig sounds like an adjustable prefab job. Honestly, though, I was
thinking esthetics and it would be easier for me and my tools to
smooth it over and clean up the excess without that pesky pin in the
way... being pulled on by gravity... in the same direction in which
it failed. Ok, I'm without proper woodworking clamps![]()
If you grease the pins before you set it in the filler you may get away with
fixing it in one move.
not sure what I would use to do this though.
Cooking spray?
like PAM?
then you could just push some JB into the hole and stick the shelf pin in.
all done except for sanding off some excess.
Could work.
Paul Hovnanian
...Jim Thompson
Jim Thompson said:More careful examination showed shelf pins to be 5mm diameter x 8mm
depth.
Trivial fix... drill out to 1/4" diameter x 1/2" depth (plywood is
3/4") and use 1/4" pin.
...Jim Thompson
If you're going to do it that cheap, just have the maid ask one ofSimple - drive some 4 inch nails through the sides. Easy as..... (and
quick - who has time for home maintenance stuff when there is a world
of interesting electronics stuff the check out....)
["Followup-To:" header set to sci.electronics.design.]
On Tue, 09 Nov 2004 16:58:13 -0500,
in Msg. said:Plywood is the good stuff.
There's still a difference between plywood and multiplex. Multiplex, often
called plywood in Europe, is the really good stuff, while plywood in the
US refers to the stuff that they make houses from, which is really crappy.
