skylar coy
- Apr 29, 2017
- 16
- Joined
- Apr 29, 2017
- Messages
- 16
man, thats dumb they should have just made 4 and 8 ohm jacks whyd they do that?The schematic shows where the wires should be connected. The switch on the jack is shown when no plug is inserted thyen the top jack is 8 ohms. When a plug is inserted into the bottom jack then it becomes 4 ohms and the top jack is disconnected.
last thing. currently, the COM wire which is labeled as going to ground on the schematic is currently being connected when a cable is plugged in to the bottom jack switching it therefore making a contact with that com wire.
So basically I can have nothing in the bottom jack, and have a 8 ohm jack up top or have something plugged into the bottom jack which will be four ohms and have the top jack disabled.
