polarity of power cord - gateway fpd1520
Z
zirath
We recently got a gateway fpd1520 (15" lcd flatscreen) monitor from
ebay. It didn't have a power cord. It says it's a 12v dc 2.5a but it
doesn't give the polarity. A person from gateway said he thought it
wouldn't hurt the monitor if it got plugged in backwards but I'd rather
not try it.
Would appreciate any help.
Arfa Daily
zirath said:
We recently got a gateway fpd1520 (15" lcd flatscreen) monitor from ebay.
It didn't have a power cord. It says it's a 12v dc 2.5a but it doesn't
give the polarity. A person from gateway said he thought it wouldn't hurt
the monitor if it got plugged in backwards but I'd rather not try it.
If it has got any external metal parts such as RCA (phono) connector outers,
BNC connector outers, 'D' connector surround etc, or possibly screws for a
stand, as these often go right through the plastic case, and into the
internal chassis, then try measuring from any such metal to each of the DC
power input connector's terminals in turn, using an ohm meter. Chances are
you'll find a direct connection, and that will be your DC ground ( "-" )
connection. The other will then be the "+". Assuming that it's a 'standard'
co-axial DC connector, on most modern equipment, 'pin' is "+" and side
contact is "-" although that's not cast in stone. Be aware when you are
obtaining a replacement PSU, that the plug is often a slightly abnormal
size, being a little larger than those you typically find on 'general' power
supplies. Also, make sure that you get one well rated for the job, as these
monitors do draw quite a lot of current, and may well surge up close to the
quoted 2.5 amps at startup, as the LCD backlights first fire up before
settling to their run current.
As to whether it would be safe to reverse connect it, I wouldn't like to
say. Some equipment is perfectly well protected against such 'consumer
antics', but it is by no means guaranteed, and if it is not adequately
protected, the result is often an item that's fried beyond repair, for no
other reason than unobtainable power supply devices, as many previous posts
on this subject over the years, will attest ...
Arfa
Arfa Daily
William Sommerwerck said:
Arfa, you're usually dead-on, but this is quite incorrect. The side of the
connector that's "grounded" is not necessarily negative! A transistor
radio
using PNP transistors would (presumably) have a positive ground, not
negative.
I think you'll find that on 'most' modern - and I did say "modern" in my
original reply - equipment, this has been pretty much standardised such that
DC "-" *is* common ground. Sony kit that I have seen in recent years has all
obeyed this 'convention', so I'm willing to bet that any Sony items that
follow the opposite 'convention', are not "modern". Pin = "-" used to be the
'convention', but for all mainstream manufacturers whose equipment I work
on, this has not been the case for many years. It was only usually the
Japanese manufacturers that followed this anyway, as I recall.
As for a transistor radio that uses PNP transistors, I haven't seen one that
uses transistors at all for many years, let alone PNP ones, so I think you
might be struggling to fit that into my "modern" category, also.
No, it's not. I have Sony equipment where the pin is negative, not
positive.
Rather than seeing which side of the power connector is grounded, I would
look to see which side of the electrolytic capacitors is grounded.
This is, of course, the very best way, if the owner wants the trouble of
taking it all to bits, and identifying a suitable electrolytic to use as his
reference. However, I would put my name on the line that the method I quoted
before, would 99.5% yield the same result, with any 'modern' item using a
coaxial DC socket. Perhaps someone out there with a Gateway monitor could
confirm which way round it is, then neither of us will be applying guesswork
to experience and coming up with sage advice ... d;~}
Arfa
BillW50
In Arfa Daily typed on Fri, 28 Mar 2008 12:52:58 GMT:
one that uses transistors at all for many years, let alone PNP ones,
so I think you might be struggling to fit that into my "modern"
category, also.
Well Arfa... they still use transistors (both NPN and PNP types) in
modern equipment. The reason you don't see them anymore is do to the
magic of minturization. But they are still there, just neatly packaged
into what is known today as the intergrated circuit (IC chip). :D
Arfa Daily
category, also.
Well Arfa... they still use transistors (both NPN and PNP types) in modern
equipment. The reason you don't see them anymore is do to the magic of
minturization. But they are still there, just neatly packaged into what is
And I though I was pedantic !! Yes, of course ICs contain transistors, and
yes, I would accept that some of them may be PNP types, depending on block
function within the IC, but I don't think, with the best will in the world,
that this is the level of transistor existence that William was referring to
with his "transistor radio using PNP transistors" scenario. In any event, in
the case of an IC taking a single polarity rail, it is irrelevant whether
the transistors inside are NPN or PNP or FETs or whatever. PNP transistors
are just used 'upside down', as are discrete PNP transistors when used in
any piece of single polarity rail equipment. The ground is still (typically
for //modern// equipment) the "-" side of the power supply / battery.
Anyway, this is getting out of hand. The OP aked a simple question, and I
gave a simple answer. This afternoon, I was in a friend's computer repair
shop. Bear in mind that he deals with monitors of all types and makes on a
daily basis. I asked him how he would go about determining the polarity of
such a monitor, and he said that he would stick one side of his ohm meter on
one of the D connector locking screws, and the other on each pin of the DC
connector. When he found the pin that read short to the connector locking
screw, it was his contention that he would have identified the "-" side of
the power supply. So that's pretty much exactly what I said. He also frowned
and shook his head, and said that he couldn't remember how many years it had
been since he had seen a DC connector that had the pin as the "-".
Which is also pretty much what I said ...
Arfa
James Sweet
"The Lady from Philadelphia" forgot the obvious. Power sockets almost
always
have their polarity marked.
I've certainly seen plenty of them that didn't though.
Z
zirath
not try it.
Thanks to everyone for your help.
BillW50
In Arfa Daily typed on Fri, 28 Mar 2008 16:07:57 GMT:
category, also.
packaged into what is known today as the intergrated circuit (IC
chip). :D
transistors, and yes, I would accept that some of them may be PNP
types, depending on block function within the IC, but I don't think,
with the best will in the world, that this is the level of transistor
existence that William was referring to with his "transistor radio
using PNP transistors" scenario. In any event, in the case of an IC
taking a single polarity rail, it is irrelevant whether the
transistors are just used 'upside down', as are discrete PNP
transistors when used in any piece of single polarity rail equipment.
The ground is still (typically for //modern// equipment) the "-" side
and I gave a simple answer. This afternoon, I was in a friend's
computer repair shop. Bear in mind that he deals with monitors of all
types and makes on a daily basis. I asked him how he would go about
determining the polarity of such a monitor, and he said that he would
stick one side of his ohm meter on one of the D connector locking
screws, and the other on each pin of the DC connector. When he found
the pin that read short to the connector locking screw, it was his
contention that he would have identified the "-" side of the power
it had been since he had seen a DC connector that had the pin as the
Arfa
That would be okay if it were a negative ground system. But like what
William Sommerwerck mentioned, we don't know that. The way I would do it
is to ohm the the power in. And the lower resistance would be the
correct polarity. Although you would need another meter to read the
polarity of the ohm meter. As they are not standardized on multimeters.
You could also use a diode (or LED) to learn of the polarity of the
meter as well.
Arfa Daily
category, also.
chip). :D
Arfa
is to ohm the the power in. And the lower resistance would be the correct
polarity. Although you would need another meter to read the polarity of
the ohm meter. As they are not standardized on multimeters. You could also
use a diode (or LED) to learn of the polarity of the meter as well.
JHC !!! Do you not understand the word "modern" ? Do you not understand the
phrase "... deals with monitors of all types on a daily basis" ? I repair
this stuff all day every day for a living. I have done for over 35 years. I
cannot remember the last time I saw a piece of kit of any description, which
employed a positive ground. My friend, who owns a computer repair shop, and
has done for many years, cannot remember the last time - if ever - that he
saw a monitor with an external power supply, that was not negative ground
with the connector sleeve as the negative connection.
With so much interconnectivity between household items now, there has had to
be a degree of standardisation on this issue, and it has evolved through a
general concensus amongst manufacturers, that negative ground will be the
convention.
As for your method of determining polarity, it makes no sense at all, unless
you are assuming a series diode, which is quite unlikely in most modern kit,
as it represents a waste of power due to its forward voltage drop. It may
even have a shunt protection diode, in which case, your 'test' will ensure
that the polarity is determined INcorrectly. Even if the device did have a
series diode, depending on where the supply first goes, there is still no
guarantee that there will be any reading at all on a standard multimeter on
ohms. If there is not any diode - series or shunt - any reading of ohms
obtained across the input socket, is unlikely to reveal anything meaningful.
What is your experience in fault-finding, I wonder, to have caused you to
have formulated such a bizarre method, and believe that it would
uncategorically give you a correct result ?
Arfa
BillW50
In Arfa Daily typed on Sun, 30 Mar 2008 14:23:08 GMT:
seen one that uses transistors at all for many years, let alone
PNP ones, so I think you might be struggling to fit that into my
the magic of minturization. But they are still there, just neatly
chip). :D
transistor existence that William was referring to with his
whether the transistors inside are NPN or PNP or FETs or whatever.
PNP transistors are just used 'upside down', as are discrete PNP
equipment. The ground is still (typically for //modern// equipment)
all types and makes on a daily basis. I asked him how he would go
about determining the polarity of such a monitor, and he said that
he would stick one side of his ohm meter on one of the D connector
locking screws, and the other on each pin of the DC connector. When
he found the pin that read short to the connector locking screw, it
also frowned and shook his head, and said that he couldn't remember
how many years it had been since he had seen a DC connector that
Arfa
do it is to ohm the the power in. And the lower resistance would be
the correct polarity. Although you would need another meter to read
the polarity of the ohm meter. As they are not standardized on
multimeters. You could also use a diode (or LED) to learn of the
polarity of the meter as well. --
Bill
understand the phrase "... deals with monitors of all types on a
daily basis" ? I repair this stuff all day every day for a living. I
have done for over 35 years. I cannot remember the last time I saw a
piece of kit of any description, which employed a positive ground. My
friend, who owns a computer repair shop, and has done for many years,
cannot remember the last time - if ever - that he saw a monitor with
an external power supply, that was not negative ground with the
had to be a degree of standardisation on this issue, and it has
evolved through a general concensus amongst manufacturers, that
negative ground will be the convention.
unless you are assuming a series diode, which is quite unlikely in
most modern kit, as it represents a waste of power due to its forward
voltage drop. It may even have a shunt protection diode, in which
case, your 'test' will ensure that the polarity is determined
INcorrectly. Even if the device did have a series diode, depending on
where the supply first goes, there is still no guarantee that there
will be any reading at all on a standard multimeter on ohms. If there
is not any diode - series or shunt - any reading of ohms obtained
you to have formulated such a bizarre method, and believe that it
would uncategorically give you a correct result ?
Arfa
Actually being an electrical engineer for 35 years, I could careless how
long your friend has been repairing computers. And the reason why the
ohm meter works is because all of the curcuits are in parallel with the
supply. Thus you will get a lower reading when the polarity is correct.
And you will get a higher reading when it is not correct. Thus as all of
the circuits are reversed biased.
Whether or not all manufactures use negative ground or not, I have no
idea. Although in all of my experience, I have learned to never assume
anything. And I have seen many strange designs. One of them had an OP
amp's output connected directly to ground. I was confused about that one
until I chatted with the designer. Then it all made sense. :)
James Sweet
the phrase "... deals with monitors of all types on a daily basis" ? I
repair this stuff all day every day for a living. I have done for over 35
years. I cannot remember the last time I saw a piece of kit of any
description, which employed a positive ground. My friend, who owns a
computer repair shop, and has done for many years, cannot remember the
last time - if ever - that he saw a monitor with an external power supply,
that was not negative ground with the connector sleeve as the negative
connection.
to be a degree of standardisation on this issue, and it has evolved
through a general concensus amongst manufacturers, that negative ground
unless you are assuming a series diode, which is quite unlikely in most
modern kit, as it represents a waste of power due to its forward voltage
drop. It may even have a shunt protection diode, in which case, your
'test' will ensure that the polarity is determined INcorrectly. Even if
the device did have a series diode, depending on where the supply first
goes, there is still no guarantee that there will be any reading at all on
a standard multimeter on ohms. If there is not any diode - series or
shunt - any reading of ohms obtained across the input socket, is unlikely
to reveal anything meaningful. What is your experience in fault-finding, I
wonder, to have caused you to have formulated such a bizarre method, and
believe that it would uncategorically give you a correct result ?
Arfa
I've been working on this stuff for years as well, not as long as you, but I
haven't been alive as long as you've been at it either. I've never seen a
positive ground either, it would make no sense to do it that way. It's just
standard that this stuff is negative ground, and that metal parts of the
chassis are grounded for shielding, I've never once seen a case where this
wasn't true so it's good enough for me. If one is still in doubt, pop the
cover off and check the polarity of the filter lytics.
Arfa Daily
chip). :D
Arfa
Bill
Arfa
long your friend has been repairing computers. And the reason why the ohm
That is unmitigated nonsense. If there is a shunt protection diode, it will
be FORWARD biased when the polarity is WRONG. Also, the fact that my friend
repairs this stuff all day, and as an electrical engineer, you clearly do
not, that makes him an expert, compared to you ...
idea.
Well, as I repair this stuff all day as well, I *do* have an idea, so that
clearly also makes me more of an expert on this particular subject, than
you ...
Although in all of my experience, I have learned to never assume anything.
And I have seen many strange designs. One of them had an OP amp's output
connected directly to ground. I was confused about that one until I chatted
In general, I would agree with you not to assume anything, but some things
are a matter of convention, and in recent years, based on my direct
experience of such things, I would stick my neck on the line, and say that
this is one, and that all modern kit, manufactured for the domestic market,
employs circuitry with a negative ground, to which (most) external metalwork
is firmly bonded.
Arfa
BillW50
In Michael A. Terrell typed on Sun, 30 Mar 2008 11:48:38 -0400:
I guess that no one bothered to check out the link I posted to a
replacement supply that not only shows it to be center positive, but
it tells you which coaxial power plug you need.
Yes we know Michael. And thanks again. :)
aioe.org is home to cowards and terrorists
Add this line to your news proxy nfilter.dat file
* drop Path:*aioe.org!not-for-mail to drop all aioe.org traffic.
Why do you say that? aioe is based in Italy.
BillW50
In Arfa Daily typed on Sun, 30 Mar 2008 16:24:25 GMT:
in modern equipment. The reason you don't see them anymore is do
to the magic of minturization. But they are still there, just
neatly packaged into what is known today as the intergrated
think, with the best will in the world, that this is the level of
in the case of an IC taking a single polarity rail, it is
irrelevant whether the transistors inside are NPN or PNP or FETs
or whatever. PNP transistors are just used 'upside down', as are
discrete PNP transistors when used in any piece of single
polarity rail equipment. The ground is still (typically for
question, and I gave a simple answer. This afternoon, I was in a
friend's computer repair shop. Bear in mind that he deals with
monitors of all types and makes on a daily basis. I asked him how
he would go about determining the polarity of such a monitor, and
he said that he would stick one side of his ohm meter on one of
DC connector. When he found the pin that read short to the
connector locking screw, it was his contention that he would have
identified the "-" side of the power supply. So that's pretty
much exactly what I said. He also frowned and shook his head, and
said that he couldn't remember how many years it had been since
Arfa
what William Sommerwerck mentioned, we don't know that. The way I
would do it is to ohm the the power in. And the lower resistance
would be the correct polarity. Although you would need another
meter to read the polarity of the ohm meter. As they are not
standardized on multimeters. You could also use a diode (or LED)
to learn of the polarity of the meter as well. --
Bill
My friend, who owns a computer repair shop, and has done for many
years, cannot remember the last time - if ever - that he saw a
has had to be a degree of standardisation on this issue, and it has
all, unless you are assuming a series diode, which is quite
unlikely in most modern kit, as it represents a waste of power due
to its forward voltage drop. It may even have a shunt protection
diode, in which case, your 'test' will ensure that the polarity is
determined INcorrectly. Even if the device did have a series diode,
multimeter on ohms. If there is not any diode - series or shunt -
fault-finding, I wonder, to have caused you to have formulated such
a bizarre method, and believe that it would uncategorically give
you a correct result ? Arfa
how long your friend has been repairing computers. And the reason
why the ohm meter works is because all of the curcuits are in
parallel with the supply. Thus you will get a lower reading when the
polarity is correct. And you will get a higher reading when it is
not correct. Thus as all of the circuits are reversed biased.
it will be FORWARD biased when the polarity is WRONG. Also, the fact
that my friend repairs this stuff all day, and as an electrical
engineer, you clearly do not, that makes him an expert, compared to
you ...
If there was a shunt protection diode, then both resistance measurements
would be forward biased. Thus you would know that since there was no
high resistance reading. But let's assume and use your plan for a
minute. There are plenty of examples where they don't ground the shield
but just let it float. Yes it sounds stupid I know, but it has been done
from time to time. And I worry about everything seemingly coming from
China nowadays. Which IMHO is only going to make things worse. And some
of this stuff from China, isn't even UL or FCC approved.
that clearly also makes me more of an expert on this particular
subject, than you ...
That is indeed possible. I always said and believed that we can learn a
lot even from a child. :)
things are a matter of convention, and in recent years, based on my
direct experience of such things, I would stick my neck on the line,
and say that this is one, and that all modern kit, manufactured for
the domestic market, employs circuitry with a negative ground, to
which (most) external metalwork is firmly bonded.
Arfa
I also have seen grounds that wasn't really ground either. Shields that
were not connected to anything. Lots of weird stuff goes on in consumer
grade equipment. Most of it IMHO is done to save a buck. Some of it is
just ingenious! And some of it is just sloppy engineering. And sometimes
it was done as a last minute bandaid just to pass FCC radio emissions.
James Sweet
It has nothing to do with where it's based. Apparently you missed the very
long thread about this a while back and the load of impostors trying to
raise hell spamming from aioe. Most of us blocked the server entirely.
BillW50
In James Sweet typed on Sun, 30 Mar 2008 21:44:11 GMT:
very long thread about this a while back and the load of impostors
trying to raise hell spamming from aioe. Most of us blocked the
server entirely.
Hi James! Oh yes I did miss that one. Thanks for the heads up.
Arfa Daily
msg said:
Arfa Daily wrote:
<snip>
I have resisted commenting but can do no longer; I don't know about the
U.K.,
but I frequently encounter negative center coaxial power equipment in my
work. These are not monitors, but a variety of consumer and industrial
portable devices. When the connector is not labeled and I don't have
docs,
I will physically inspect the internal wiring or the pcb that hosts the
power
connector and also do resistance measurements between ground planes and
the
power connector contacts to determine ground. The assumption that ground
planes are negative is a given in most instances. As for the subjective
label "modern", that is a religious issue that shouldn't be a factor in
good electronics practice ;)
Michael
Michael. I'm not quite sure exactly what you are saying here. I do not doubt
that you encounter equipment with a negative pin connection on the coaxial
DC connector. I have not disputed this during this thread. In fact, I
actually said in my original reply to the OP, that although these days, pin
= "+" is the common convention, it is by no means cast in stone. I'm sure
that even though you do have dealings with negative pin equipment, you would
concede that positive pin is by far the more common at this point in time,
and has been for some years. Irrespective of which pole of the connector is
the positive one, you seem to accept that ground being negative is the "...
given in most instances", which is what most of the controversy generated
within the thread, has been about. So as far as I can see, we are both 'on
the same page'.
I don't understand what you are saying about the word "modern". It is quite
a well defined word, and fits well, in this context, with the dictionary
definition
http://dictionary.reference.com/browse/modern
particularly with the entry that refers to it being something that is "not
obsolete". Whilst you are correct that it is a subjective word, in the case
of electronic equipment, I would contend that most electronic engineers
would infer something of the order of 8 -10 years to be meant, when calling
electronic equipment "modern".
And Bill.
I will now explain why your contention that your method will work under all
circumstances, is not valid. You are quite wrong with your assumption that
all of the circuits in a piece of equipment are stacked up in parallel
across the DC input socket. Whilst this might have been the case some years
back, the DC connector on "modern" (infer whatever period you like from that
word) equipment, usually connects straight into some form of internal
ancilliary power supply, or a regulator or regulators, which are often
switching types.
The reasons for this are manifold, but include the fact that most modern
equipment does not contain circuitry that runs just from 12v, which is a
typical 'standard' value for external power unit equipment, and also
efficiency, which dictates the regulators typically being switchers. The
various circuits contained within the equipment, are connected to the back
end of these regulators, and are thus not connected to the DC power socket
in any way.
Often, the input to this regulator circuitry, contained within special
purpose ICs, will not produce any meaningful ohms reading, when subjected to
the low test voltage from a multimeter. So, you are just as likely to read a
virtual open circuit across the socket, irrespective of which way round you
have your meter. This, in itself, will not help you to determine the
polarity. But worse. If the unit employs a shunt protection diode, when your
meter is connected //backwards// to the correct polarity, you will get a
reading of 700 ohms or so, but when it is connected the //correct// way
round, you may well read infinity or near. By your definition of how your
system works to determine polarity, that would give you a clear indication
of which was the correct polarity, but would actually yield the *INcorrect*
polarity.
As for external metalwork not being connected to the internal common ground,
these days, that is rare. I do come across the situation sometimes, on AV
amps, where the RCA socket sleeves are floating with respect to the chassis,
but it is the exception rather than the rule, and is done to help alleviate
potential ground loop issues when connecting to other equipment.
As far as the polarity of the ground goes, I am prepared to say that in my
considerable experience, on modern equipment designed for the consumer
market, it is always negative. And that really is about as cast in stone as
anything in electronic design ever is. I could of course be wrong on this,
but if anyone wants to correct me with specific examples - remembering
"modern" and "domestic", I'm listening, and willing to modify my position on
it.
I say again, that the OP asked a simple question, to which there was a
simple answer. I don't really believe that there was any need to muddy the
waters to the extent of all of this silly stuff that has been put forward,
but hey - ho. I guess it all makes for an interesting life ... d;~}
Arfa
BillW50
In Arfa Daily typed on Mon, 31 Mar 2008 00:37:00 GMT:
And Bill.
under all circumstances, is not valid.
Sorry if you got that impression, but that isn't what I meant.
assumption that all of the circuits in a piece of equipment are
stacked up in parallel across the DC input socket. Whilst this might
have been the case some years back, the DC connector on "modern"
(infer whatever period you like from that word) equipment, usually
connects straight into some form of internal ancilliary power supply,
or a regulator or regulators, which are often switching types.
Yes I remember.
modern equipment does not contain circuitry that runs just from 12v,
which is a typical 'standard' value for external power unit
equipment, and also efficiency, which dictates the regulators
typically being switchers. The various circuits contained within the
equipment, are connected to the back end of these regulators, and are
thus not connected to the DC power socket in any way.
Yes but the regulators are.
subjected to the low test voltage from a multimeter. So, you are just
as likely to read a virtual open circuit across the socket,
irrespective of which way round you have your meter. This, in itself,
will not help you to determine the polarity.
Yes... so if you have a high/low resistance readings, this is very
useful. If you have a low/low or a high/high, checking the resistance
isn't useful under these conditions.
employs a shunt protection diode, when your meter is connected
//backwards// to the correct polarity, you will get a reading of 700
ohms or so, but when it is connected the //correct// way round, you
may well read infinity or near. By your definition of how your system
*INcorrect* polarity.
True, but it will not hurt anything. As the shunt will only allow about
a negative 0.7v to the rest of the unit. So unless the shunt blows, it
shouldn't ever hurt it. You can possibly damage the adapter, but it
should be protected against such anyway. But it is cheaper than the unit
it is powering anyway. ;-)
ground, these days, that is rare. I do come across the situation
sometimes, on AV amps, where the RCA socket sleeves are floating with
respect to the chassis, but it is the exception rather than the rule,
and is done to help alleviate potential ground loop issues when
in my considerable experience, on modern equipment designed for the
consumer market, it is always negative. And that really is about as
cast in stone as anything in electronic design ever is. I could of
course be wrong on this, but if anyone wants to correct me with
specific examples - remembering "modern" and "domestic", I'm
listening, and willing to modify my position on it.
Yes I agree. But thinking that way, you may fry every positive ground
you come across. If that is an acceptable risk for you and others...
well what can I say? While some risks are acceptable to me, frying
something because you had the polarity wrong just isn't one of them. LOL
muddy the waters to the extent of all of this silly stuff that has
been put forward, but hey - ho. I guess it all makes for an
I believe having enough information to make a wise choice is far better
than bozos telling you that you have to do it this way and there are no
becauses. :D
Arfa Daily
And Bill.
Yes I remember.
Yes... so if you have a high/low resistance readings, this is very useful.
If you have a low/low or a high/high, checking the resistance isn't useful
True, but it will not hurt anything. As the shunt will only allow about a
shouldn't ever hurt it. You can possibly damage the adapter, but it should
be protected against such anyway. But it is cheaper than the unit it is
Yes I agree. But thinking that way, you may fry every positive ground you
come across. If that is an acceptable risk for you and others... well what
can I say? While some risks are acceptable to me, frying something because
becauses. :D
Well, I guess we could go on dancing around this one for ever ...
With the circuit loads being connected to the back end of regulators that
are likely to have high input resistances with respect to the low test
voltage supplied by a multimeter, you really are unlikely to read anything
meaningful across the DC input socket. Trust me. I do this (very
successfully) for a living. Reading high-low, low-low, high-high, is
fundamentally useless to determining input polarity, unless you have a
schematic for the equipment to know what you are looking at. If you had a
schematic, you would not, of course, be trying to determine the polarity in
the first place ...
It is also not necessarily true that you will damage nothing if you do
arrive at a wrong conclusion as a result of applying your ohm-meter test to
an equipment which employs a shunt protection diode. Remember that the power
supplies for LCD TV sets and monitors, when these are external types, are
capable of supplying typically 2 to 4 amps. This is plenty enough to destroy
a typical 1 amp shunt diode, or to blow a pico or surface mount fuse, as is
typically found in such devices, or even to take out print, which is
sometimes deliberately 'necked' to provide a fuse function. Shunt protection
diodes seldom survive a reverse connection. Ask anyone who repairs CB
radios, or PMR radios, or plain old car entertainment radios.
Even if no shunt diode is used, there is still no guarantee that any
regulator device which has reverse polarity applied to it, will survive. I
have seen plenty that haven't.
I honestly don't believe that I am going to fry *any* positive grounds that
I come across, for the simple reason that on modern equipment, I just don't
come across them. They died out pretty much with germanium PNP transistors.
Obviously, if I was trying to determine the polarity of a piece of 30 year
old kit, I would take the trouble to employ different methods to do so, on
the off-chance that it might have a positive ground, but again, trust me,
positive grounds simply *aren't* encountered on modern equipment.
I hope when you refer to "bozos", you are not including me in that, as it
would cause me to take extreme offence at you. Having enough information to
make a wise choice is indeed a laudable objective, but discounting the
advice of someone who has more than 35 years declared experience in a field,
borders on stupidity. I certainly would not tell anyone that they *must* do
it this way, but if I believe, based on my considerable experience in the
repair field, that a particular method is likely to yield a correct answer
with a better than 95% certainty, then I am going to advise them of this,
which I believe is the way I approached the OP's original question, in the
first place.
Whilst there are always "becauses" as you put it, in this particular case,
their validity is negligible, for all of the reasons that I have
(painstakingly) explained over and over.
Arfa
