Power supply ratings
champ1
Jul 17, 2018
55
Hello
I am looking information for this 24V SMPS
It has a rating 24V Dc, 5.0A
so It means it can supply maximum 24V DC and 5.0A current
I want to calculate a minimum voltage and current it can supply
How to find minimum voltage and current it can supply to load ?
Output voltage is 24V, that's it.
Current drawn will depend on your circuit BUT only to a maximum of 5Amp.
Suggest you do a bit of basic electrical 101.
AnalogKid
Jun 10, 2015
3,055
As above and from the labels on the device, it has a fixed, constant 24 V output. You can draw constantly any amount of current up to a max of 5,0 A.
Note - if this is a switching supply, it might have a minimum output current requirement. Check the datasheet or owner's manual. many switchers require a minimum load of 10% of the rated output current. In your case that would be 0.5 A. The transformer and regulator circuit in a switching supply are very different from those in a linear supply. In particular, the transformer requires a minimum amount of energy through it to stabilize its performance.
ak
champ1
Jul 17, 2018
55
Does it provide a constant 5A to load?
How much minimum current it can be drawn?
duke37
Jan 9, 2011
5,364
Did you read #2?
The output voltage is 24V DC and can be adjusted slightly by the screw.
The minimum output current will be zero if nothing is connected:).
The actual current (5A Max) will be what the load demands. The limit may be by a current limit circuit, a fuze or by a fire.
