[email protected]
- Jan 1, 1970
- 0
Could some electronics guru please shed
some light on the following. The standard
topology for a linear regulated power
supply is basically as follows:
isolation step-down transformer
v
rectifier(bridge or 2 - diode)
v
capacitor ripple filter bank
v
voltage regulator
v
V
Let us suppose that the transformer is a
step-down 9 - 0 - 9 1 Amp output device.
Now suppose I want to get two 1 Amp outputs
by having a 9 - 0 -9 2 Amp transformer and
splitting its output equally with resistors
as :
v v
resistor resistor
V V
rectifier etc., rectifier etc.,
Is this a valid topology ? Or should there
be two 9 - 0 - 9 1 Amp isolation transformers
connected to the common Ac wall input, and
then parallel topology as above, without the
resistors.
Any thoughts, suggestions would be appreciated.
Thanks in advance.
v
v
v
voltage regulator
v
V
as :
v v
resistor resistor
V V
resistors.
Thanks in advance.
