Re: Quick basic advice on a dripping gas 40-gal hot-water heater
  • Thread starter Donna Ohl, Grady Volunteer Coordinator
  • Start date
This could turn into a whole new thread of major f*ckups that we learned
from....
So far, on my side of the story, the water heater, full of tepid water,
fell over, and the drain valve popped off spewing water about. I won't soon
forget that! The garage still stinks of smelly carpet!
The replacement of the water heater seems to have clogged all the faucets
(easy to clean), showerheads (even easier to clean), tub (still clogged),
and maybe even the dishwasher (work in progress).
I'm not sure *where* the sand came from but it's clearly in all the faucets
so I guess we kicked it loose somehow in the water heater removal and
replacement process.
Anyway, now it's time to "remove" the dishwasher, if I can.
Does it look like it can be removed from these pictures taken today?
Counter Top:
http://www.flickr.com/photos/donnaohl/2279233722/in/set-72157603947125744/
Latch:
http://www.flickr.com/photos/donnaohl/2279869536/in/set-72157603947125744/
Bottom Right:
http://www.flickr.com/photos/donnaohl/2279869542/in/set-72157603947125744/
Bottom Left:
http://www.flickr.com/photos/donnaohl/2279869546/in/set-72157603947125744/
Do you think this dishwasher can be removed without breaking the counter
tile?
Donna
Any good installation of an appliance like a dishwasher
should have a filter screen / rubber washer fitted to the hose fitting to
the tap that controls the water to the appliance
Hi Only Just,
Another great confidence booster!
Given that wonderful suggestion, I snapped some more pics, just now, of
under the sink where the dishwasher water seems to be coming from instead
of looking under the "kickplate" where the dangerous-looking wires are.
It looks like a wire and two hoses come out of the dishwasher:
http://www.flickr.com/photos/donnaohl/2279911402/in/set-72157603947125744/
The white hose seems to go to the garbage disposal
http://www.flickr.com/photos/donnaohl/2279911408/in/set-72157603947125744/
The steel hose seems to come from the (badly corroded) hot water input:
http://www.flickr.com/photos/donnaohl/2279911438/in/set-72157603947125744/
Something, I'm not sure why there are three hoses, goes into the sink:
http://www.flickr.com/photos/donnaohl/2279911420/in/set-72157603947125744/
Does something here look like what you are describing might be clogged?
http://www.flickr.com/photos/donnaohl/sets/72157603947125744/
Donna
I just installed a couple dishwashers, one for us and one for a
friend, and one for a friend, no screen washers,,,,,,,,,
Hi Hallerb,
I'm sorry I didn't see this earlier. I'm so confused with this discussion
as to where to post.
I hope others can keep up as I read *everything* everyone says and try to
answser the questions so I can help myself and others can follow after
we're done so the advice is never wasted.
I took a bunch of pics of the dishwasher today and put them here:
(Flicker apparently allows only 3 sets so I have to mix the dishwasher clog
with the tub clog which is, in a way, the same problem as it happened after
the water heater replacement).
I did do research on clogged dishwashers but it's hard to find anything
specific to the GE Nautilus.
This article says "unscrew the water inlet hose" to remove sediment:
http://www.rusticgirls.com/appliances/dishwasher-not-filling.html
This one says "debris" could be caught in the "spray arm":
http://www.mrappliance.com/expert/manual/dishwashers.aspx
This one again points to the "filter" and "solonoid":
http://www.home-appliance-kitchen-aids.com/dishwashers.html
This one suggests it might be the "float" that's clogged:
http://www.applianceandair.com/Dishwasher/dishwasher.html#nofill
I think what I'll do later today (I have the grandkids again) is take apart
the inlet line and the solonoid line if I can.
If I see sand in there, I'll know it's the problem!
Any other suggestions?
Donna
Hey that looks identical to the one I just yanked out of my place
When you remove the kick plate, you'll find adjustable screw feet
The solenoid valve will be right up front on the left side, mine is blue.
Hi James,
You gave me the courage to tackle this maybe-clogged dishwasher:
Here's a pic, taken just now, with the "kick plate" removed:
Are you suggesting I can remove that blue "solonoid" on the left side with
the brass pipe in it and that might be what's probably clogged?
Donna
GregS
Hi James,
Donna
I might first think about using a good shop vac and start sucking at the feed
from the water heater or main entrance. open all taps, and of course close
main valve. I think the line would have to reseparated at the tank. The
dishwasher fill would have to be activated to open valve.
greg
GregS
greg
Do one tap at a time, or valve.
greg
Hi GregS,
Unfortunately, we do not have a "shop vac". My vacuum cleaner isn't likely
to do the job either ...
I will try tonight to remove the inlet water line if I can find where it
goes and to remove the solonoid to see if either have a screen.
If it's not that, then I'll look at the "float" and the "nozzle" wherever
they are, but first I'll try to see if it's the blue solonoid or the hidden
inlet screen if there is any.
Donna
If it's anything like the little filter screens on the hot water and
cold water inlet pipes to clothes washers machines, those little filter
screens should occasionally be cleaned.
cuhulin
Hi GregS,
Donna
clog can be anywhere and is likely multiple locations.......
good luck and replace you galvanized ASAP the rough interior surface
of galvanized pipe leads to gunk accumulating and breaking lose
causing clogs of all types.
soleanoid valves are easy to replace but expensive
James Sweet
In the unlikely event that it needs it, she can have the solenoid from my
junk dishwasher, I haven't had a chance to haul it to the dump yet. I see
free dishwashers on craigslist all the time, most are made by just a few
different brands and have many parts in common.
O
Only Just
soon
faucets
Counter Top:
Latch:
Bottom Right:
Bottom Left:
tile?
Donna
You can only try to get it out but to avoid problems try clearing the hose
first then worry about pulling the dishwasher out from its location. It
always annoyed me when I had to remove them from the benches for servicing
when I did it for a living as kitchen builders seem to always work to very
close fitting making it nearly impossible to remove and that is when it is
all built as a full unit. They never allow for variations including putting
down a new floor or replacing the unit whereas the new unit is usually a
different size, cupboards can easily be built up or facias placed in but
removing tops and cupboards is more difficult and expensive. At least it
looks easier for you as you have a level tile floor which will be easy to
slide it on and not damaged as easily.
Good luck and waiting for the result.
Just.
Michael A. Terrell
Counter Top:
Latch:
Bottom Right:
Bottom Left:
tile?
Donna
I always open an outside faucet wide open for about five minutes any
time the water is turned off to blow as much crap out of the lines
before using anything inside the house.
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
Hi Michael,
This is a GREAT idea! (if it works).
What I don't get is WHY there was all that sandy stuff after I replaced my
wagter heater. If anything, there should be LESS sediment in the lines, not
more (way more).
Where did all that sandy sediment that clogged every single faucet in our
tiny house come from?
Is this common that sediment blocks everything in one quick pass after
replacing a water heater?
If so, why did NONE of the tutorials I read mention that simple hint you
just gave us?
Donna
Hi Michael,
more (way more).
just gave us?
Donna
ahh when you turn off the water, drain the lines, and turn the water
back on. did you note the shuddering the first time you used water?
thats normal but you have galvanized lines full of crud which broke
loose and clogged stuff.
PEX and copper have smooth insides which dont collect crud.
sorry donna you need all your water lines replaced.
incidently water companies have the same trouble, and this is whu they
flush fire hydrants a couple times a year. confirms the hydrant works
and moves along dirt in lines.
thats why flushing sometimes causes brown or cruddy water
thats why flushing sometimes causes brown or cruddy water- Hide quoted text -
- Show quoted text -
with copper of plastic lines its a non issue, and few today have
galvanized.
my neighbor got severly burnt at work after a water outage. when it
was turned back on the hot tea machine sprayed scalding water all over
her hand. she has permanent nerve damage
Hi Hallerb,
Ah. Yes. When the water was turned back on, there was a lot of sputtering
and shuddering going on, mostly sputtering. I thought it had to do with the
new burner.
http://www.flickr.com/photos/donnaohl/2276890136/
But, this shaking & flushing of the pipes must have shaken loose sandy
grainy "crud" as every galvanized pipe I replaced was almost clogged
completely with what you called "scale".
http://www.flickr.com/photos/donnaohl/2273250265/
The water *was* brownish for a long while (you can see that in this photo
even after cleaning out the showerheads, so the crud was *still* coming
through the lines even ten minutes after initially turning the water back
on!
http://www.flickr.com/photos/donnaohl/2279233720/
I guess all that brownish was sandy grainy stuff that caught in the filters
of *all* my faucets, showerheads, and dishwashers!
Nobody warned me about that so I'm *adding* it to the how to that I wrote
up!
James Sweet
Hi Hallerb,
the
new burner.
on!
filters
up!
The sputtering is due to air in the lines, it gets trapped in all sorts of
places and sputters and spurts out when a tap is opened.
I've only ever seen a couple houses that had galvanized pipes, and in one
case they were all being replaced. The sediment problem is something mostly
specific to galvanized, so it's not on the radar for most people.
msg
Huh? Look most anywhere in the 'rust belt' or in areas where the housing
stock is largely greater than 80 years old ;-) Too bad that 'tutorials'
aren't directed at those situations to which they are most needed.
Michael
James Sweet
I'm not anywhere near the rust belt.
I know several people with old houses that originally had galvanized, but
they're all copper now.
