Re: Quick basic advice on a dripping gas 40-gal hot-water heater
  • Thread starter Donna Ohl, Grady Volunteer Coordinator
  • Start date
Awww, come on,,,, buying and installing a new water heater is hardly any
different than buying and and installing any other kind of a home
apppliance.There is nothing to it but to do it.A city permit? Forget it!
cuhulin
Michael A. Terrell
with copper of plastic lines its a non issue, and few today have
galvanized.
my neighbor got severly burnt at work after a water outage. when it
was turned back on the hot tea machine sprayed scalding water all over
her hand. she has permanent nerve damage
All my plumbing is PVC, except the well casing. The people I bought
the place from waited till the old well was totally useless, and there
is 1/8" of rust on the walls of the PVC. Every time the system, is
deperssurized, I get VERY rusty water, unless I flush it, as described.
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
Michael A. Terrell
Donna Ohl said:
Hi Michael,
This is a GREAT idea! (if it works).
What I don't get is WHY there was all that sandy stuff after I replaced my
wagter heater. If anything, there should be LESS sediment in the lines, not
more (way more).
Where did all that sandy sediment that clogged every single faucet in our
tiny house come from?
Is this common that sediment blocks everything in one quick pass after
replacing a water heater?
If so, why did NONE of the tutorials I read mention that simple hint you
just gave us?
Who knows? They probably overlook it, thinking that everyone already
knows about it. People who are too close ot any subject tend to mitt
important details, because they think everyone knows THAT about the
job. I rewrote a lot of test procedures where I worked, because of the
engineering department doing the same thing. You had to train each tech
on each job, because so much stuff was left out, or just plain wrong.
Eventually, the system was changed to peer review the documents on the
test floor before changes were approved.
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
John
Hi Nate,
That brings up the first (of many) questions that arose when we
replaced our hot water heater (with your help) yesterday ...
1. I agree, while replacing the altruistic anode is a "good thing"
http://farm3.static.flickr.com/2086/2274079124_f60ec145cf.
jpg?v=0
The problem I found is ...
2. Even Superman couldn't would have a tough time removing mine ...
http://farm3.static.flickr.com/2033/2274085498_52c3b7d618.jpg
?v=0
Given it took a pipe wrench plus a huge cheater bar to remove the
anode with the water heater removed and blocked on the ground ...
and given that any in-place plumbing and vent ducts would have
severely hampered access ... and given that a water heater isn't
rigidly "mounted" ... I wonder ...
Can anyone really expect to remove the anode when it needs
inspection? Why don't they provide TWO HOLES so you can add a
second anode when needed?
Donna
http://www.flickr.com/donnaohl
Hello Donna, you seem to have learnt quite a surprsing amount for
someone who has was a novice just a few weeks ago and who does not
have a background in mechanical engineering.
I'm impressed.
Or i would be impressed if I could believe it but I am afrain I can't
beleieve it.
What did you say was your line of work?
If you have time when you're not posting extended posts to a "quick
and basic" question?
Donna Ohl
Hello Donna, you seem to have learnt quite a surprsing amount.
Hello John,
I wonder why intelligence bothers you so very much.
Michael A. Terrell
Donna said:
Hello John,
Donna, some people would bitch if you hung them with a new rope.
aioe.org is home to cowards and terrorists
Add this line to your news proxy nfilter.dat file
* drop Path:*aioe.org!not-for-mail to drop all aioe.org traffic.
http://improve-usenet.org/index.html
Donna Ohl
Thanks for the kind words Michael.
I think it bothers them that anyone could learn as much as I did from you
guys and that we could solve the problem together, even though it took a
while.
Here, for example, is my picture today where I finally got the courage to
take the blue dishwasher solonoid apart and you guys were right! The filter
was completely clogged with sand!
http://farm3.static.flickr.com/2269/2336387621_7655ae468a_m.jpg
Without your advice, I would never have been able to know what to take
apart to find the problem!
I hope, by posting the pictures and describing what we've learned together,
that the next person reading this who has a clogged dishwasher after doing
a water heater repair, will know exactly what to do!
Donna
