Repair - Breville Sandwich Toaster
Status
Not open for further replies.
Merton69
Aug 6, 2021
33
Hello All.
Before I chuck it, I thought I would at least have a go at repairing it.
I have a late 70's sandwich toaster that needs a replacement cable that connects the upper plate to the lower cooking plate. It was working fine until there was a spark, a major glow from the cable, then nothing! You can see from the spring/coil protector where the break was.
Needs a bl*ody good clean but will only do this if it can be mended.
From the images, hopefully you can see the cable I need.
Please can anyone tell me what cable is needed?
Would be great to repair/recycle rather than going in the ground.
Thanks!
14,317
Any heat resistant power cord with a wire diameter matching the one in your toaster should be suitable.
I can't see that to clearly but it looks like the cable was put inside an additional high temperature sleeve before this was threaded through the spring.
It also looks like Faston terminals were used to make the electrical connections. You'll need these and a suitable crimping tool, too. Maybe an electrician can help you with this part as the crimping tool is likely to be more expensive than a new toaster :(
Merton69
Aug 6, 2021
33
Thanks Harald for your indepth knowledge and info.
I have various terminals so that is no problem.
My problem is finding the suitable cable. I wouldn't know where to start. So would you be able to show a suitable cable from eBay/Amazon etc. (as you have superbly done with the terminl and sleeve) as an example for me to do further research and pricing etc?
Thank you for your time in this matter.
Bin it before the wife or one of the kids gets a liven up from dodgy electrical repair.
Merton69
Aug 6, 2021
33
Thanks but I will still like my questions to be answered. Let ME make the decision, thank you.
14,487
Sorry ....
Then no one here can help you as none of us want to be implicit in helping you do something
that may cause injury or worse because of your lack of knowledge
Status
