Repair of Dewalt dcb101 battery charger
suppala
Feb 26, 2017
16
message continued .The 60 watt bulb mentioned by you must be of 110 volt .In India it is difficult to get 110 volt bulbs. I do not know how critical the bulb resistance is . To get same resistance of200 ohms , I can use 4 bulbs of 60 v ....... Uppala
73's de Edd
Aug 21, 2015
3,730
I believe that if you use a 220V incandescant type it will work also, but just come to a red glow on 110 input instead of its normal brilliant brightness on 110.
suppala
Feb 26, 2017
16
I did not see your reply till yesterday as I was all along looking at page 1 only. Today, I tried the lamp test with a 40 watt lamp, and found the lamp glowing dim and going off in seconds . On my second or third attempt ,I even saw the led lighting up. On checking ,I found 60 volts steadily dropping at a slow rate at the bigger condenser. I did not continue for long as I did not use suitable probes and I had to hold two flexible wires by hand and try to make contact with unsteady hands of a 80 plus aged . I will try a longer test by tomorrow to build up voltage , unless it needs a bulb of much higher wattage . What next , Thanks ..Uppala on May2,2017
After another couple of seconds the voltage has gone upto 104 DC . Now , I am certain with testing for a minute or more , It should go upto 170 plus.
suppala
Feb 26, 2017
16
Dear 73's de Edd,
In view of my above findings .can I now connect up an equivalent fuse without further problems or is a further check necessary ? I have with me a 2R9 resistance fuse with me . This is circular ,pc mountable and looks similar to a resettable fuse . Can this substitute the bell radial tag fuse ,
s Uppala ,9. 2017
bigone5500
Apr 9, 2014
712
Not the scope of this thread but those chargers go for about $25 USD. Found them on ebay. This could be your last resort if you give up on repair.
suppala
Feb 26, 2017
16
My reply got deleted . However I am retyping after 20 minutes
Attention"73's de Edd . My earlier testing was incomplete as I could not check the second smaller 250 volt capacitor . Today , I could check this capacitor and find it is not building up any voltage beyond 2 to 6 volt DC. Also the bigger one was able to build up upto 160 volts only. These tests are done after taking off lamp fuse leads as I could not handle dmm leads and fuse leads at the same time . Let me know if the capacitor plus any other parts need change . Another factor I noticed is that led lights up every time I connect lamp across fuse terminals , but goes off immediately...suppala
