Repairing PHP 2026 Massage Chair
Joyful Sandy
Oct 24, 2018
3
I just had an electrician take my chair apart. He tells me it is not the transformers; I need a new circuitboard. He said the number is 2026 C1 PCB. Anyone have an idea of where I could get or order that?
dave9
Mar 5, 2017
1,191
You should have continued on in the topic you recently created instead of starting a new one.
There are some resources in the following topic, which also indicates that the company is out of business so the sources for a replacement mainboard might be limited to Amazon or eBay, but as always I would look into whether the circuit can be traced and a discreet component fault on the board found... which can often cost only $10 or so for a component instead of $$$ for a circuit board.
However I can imagine it could be hard to share with us all the various wiring and motors in pictures to try to reverse engineer this remotely so if you can't DIY, and if you can't find a board either, the next best step would probably be to hunt down an electronics repair shop in your area, something ran by an old timer that has been repairing TVs/stereos/etc for decades (not a commercial chain Best Buy geek squad/etc service center), then you hope they don't mind you dragging a chair to them since it's going to be larger than what they're used to dealing with.
https://www.electronicspoint.com/th...-products-php-2026-2027-massage-chair.283587/
Joyful Sandy
Oct 24, 2018
3
Thank you for your response. The chair weighs 200 pounds so I can’t drag it anywhere.
dave9
Mar 5, 2017
1,191
Well I figured you'd have someone helping and maybe a truck or at least a skateboard to move it. ;)
