Replace 680uf capacitor on a Vizio VW 42L LCD w/ a 1000uf capacitor
jmanibusan
Jan 3, 2016
Need to replace a 35v 680uf 105° Capacitor on a Vizio VW42L FHDTV10A. Will a 35v 1000uf 105° work just fine. local radio shack don't carry the exact part.
14,487
hi there
welcome to EP :)
presumably it's in the power supply section ?
in such cases increasing the value isn't a problem as long as it will fit into the same spot :)
and it also has the same or higher voltage rating
jmanibusan
Jan 3, 2016
hi there
welcome to EP :)
it's on the Inverter board. would it still be fine?
Martaine2005
May 12, 2015
5,318
Are you assuming bad caps on the inverter board?
These TV's, apart from the 24v from the power supply also have a 5v 'turn on' from the main board. Bad caps on the main board can point to a dead inverter too..
Just my 2 cents..:)
Martin
