RMS and Average Current
F
Fred Bartoli
John Larkin said:
RMS volts * RMS amps <> RMS watts in the general case. It is true
here, so long as the diode forward drop is flat during the pulses.
Only true in the case of a resistor.
Make that a diode rectifying 0.5A average on a 1000V circuit and you meter
wi'll make you need a pretty huge heatsink for you DO41 diode.
The Phantom
"The Phantom"
** You could easily get that diode " on "voltage accurate to 1 or 2%.
Just check the scope range with a good 1.25 volt reference.
Before I respond to specific items, let me say that all my comments have
assumed that we were dealing with line frequency currents. The OP didn't say
explicitly that he was concerned with line frequency rectifiers, but he *was*
concerned with power dissipation in a diode. Typically, signal rectifiers
aren't dissipation limited. It's usually line frequency rectifiers or,
nowadays, diodes in switching power supplies where power dissipation is a
concern. To keep things simple, I assumed line frequency. You may not think it
was a reasonable assumption; if so, then we will have to differ.
** That is absolute crapology.
The diode *on* voltage is wanted - in isolation from any reverse voltage -
something a DMM cannot do.
Sure it can. Have a look at the URL John Larkin posted:
http://us.fluke.com/usen/products/prodSelection_Grouping.htm
All of the DMMs there have a MIN-MAX function which can easily get the diode on
voltage at line frequency. As I said in a posting, you need a peak responding
meter, and that's what MIN-MAX does.
Ergo - a scope is the way to go.
DMMs with "true rms" capability vary ENORMOUSLY in their effective
bandwidth - most are only accurate to a few kHz - making them useless
for other than AC supply related waveforms.
I can't comment on your experience, but my own differs. Every DMM I have used
on the job has had substantially greater bandwidth than a few KHz. I personally
own three DMMs. The two handhelds, an HP 974A and a Fluke 189 both have 100 KHz
bandwith. My bench meter is a 20 year old HP 3468 with 300 KHz bandwidth. The
lowest bandwidth shown on the Fluke site referenced above is 20 KHz.
But this isn't relevant to my postings since I was assuming line frequency.
OTOH - even garden variety scopes are accurate to tens of MHz !!
An *average responding* amp meter WILL give the correct result since
response time becomes irrelevant.
You need to try a lot harder, Mr Phantom.
John Larkin first posited "...a clean rectangular pulse..." in this thread,
something that will scarcely ever be seen in practice. In line frequency
applications, one usually sees currents looking like pieces of sinusoids, or
rounded pulses as in a capacitor input filter. In switchers, the pulse currents
in diodes range from triangle waves to trapezoids, but are rarely flat topped.
So neither method will work well in practice to determine diode dissipation. As
I mentioned in another post, one would have to use a wattmeter (good to low
audio frequencies, if it's an old fashioned dynamometer type), or a scope with
trace math, or some other purpose-built piece of equipment.
But John's hypothetical is a simple case which you used to point out that the
power delivered to a constant voltage by a varying current is proportional to
the *average* value of the current. This is quite true, and, I dare say, often
overlooked.
I merely pointed out that since the voltage across the diode isn't absolutely
pure DC, but is a pulsed waveform like the current, the measurement can be made
by measuring the true RMS voltage and current and multiplying the two.
This is an idealized situation and my comments were intended to be taken as
applying to an ideal where accurate RMS measurements could be made, much as your
method only works for the ideal situation where the pulse is flat topped.
John's description led me to think that his "clean rectangular pulse" might be
coming from a pulse generator, and so I assumed that there was no reverse
voltage across the diode. If there is, then it can be blocked by another diode;
and if that diode's forward drop causes too much error, it can probably be
compensated.
*Of course* it's true that if the measurements are in error because the
waveform is at a frequency beyond the capability of the DMM, then this method
won't work. I never claimed otherwise.
Pooh Bear
Phil said:
"Poopie Bear Faced LIAR "
** Another, malicious, trolling pommy pig.
You *CUT THE CONTEXT *
You billabonging swine !
Phil Allison
"Poopie Bear Faced LIAR " ...
aka Graham Stevenson :
Grandiose, bipolar ADHD stuffed brit & all round puke
** You did not post a point in context.
Just another brainless personal jibe from vile, criminal charlatan enraged
by being continually publicly outed.
......... Phil
The Phantom
Hi, Fred! See another post I made in response to Phil. I did assume that
there was no reverse voltage across the diode. Since John Larkin talked about a
"clean rectangular pulse", I considered the simplest case where the driving
signal came from a pulse generator and was only positive or zero. I assumed
this, because in practice in most power handling circuits, you won't see a
"clean rectangular pulse". Hence, it seemed to me that it was an idealized
situation under discussion.
So, if the flat-topped current through the diode is I amps, and the "on"
voltage is E volts, you can replace the diode with a resistor of value E/I ohms,
and you will see exactly the same waveforms. And the dissipation in the
resistor will be RMS volts * RMS amps, and also in the diode. This is only
true if the voltage across the diode doesn't vary during the pulse.
If the voltage across the diode during the "on" time of the pulse doesn't
change (remember the current is constant during the "on" time) due to heating or
some other cause, then you wouldn't be able to tell that it wasn't a resistor
(assuming no reverse voltage, as I said above). Although I suppose that if the
voltage did change you could attribute it to heating of the supposed resistor.
But it might change in a more "diode like" manner if it were really a diode; ah,
well, one complication after another.
Pooh Bear
Surely that's *your* stock-in trade.
Foe God's sake take the pills !
Graham
Phil Allison
"The Phantom"
** That is an INSANE assumption to make.
Par for the course with ranting nut like you.
** Go read some specs on low cost DMMs - shithead.
Your lack of "experience " is your problem.
frequency.
** Asinine.
thread,
** It was however Mr Larkin's words that I commented on.
YOU were NOT following the context.
the
to
often
overlooked.
** Yawn - what a desperate wanker.
absolutely
made
as
** Blatant lie based on having second thoughts.
much as your
** Absolute bullshit.
The diode clamps its on voltage to a narrow band.
What a lying fuckwit.
might be
** What a fuckwit.
compensated.
** The fuckwit is clutching at straws now.
method
won't work.
** My suggested way WILL work with a basic scope and cheap DMM.
As found in any electronics workshop.
NOW : Piss off you PITA TROLL !!!!!
........... Phil
John Larkin
The op specified a "pulsed waveform" and wanted to calculate diode
power dissipation. For either a regulator efficiency calculation or
for sizing a heatsink, 20% accuracy should be good enough, so
reasonable approximations should be OK. For the purposes of flame
waring, there is no such thing as "reasonable approximations."
John
Michael A. Terrell
Graham
Forget the pills, drink the kool-aid.
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
John Larkin
Actually, just about all but the cheapest of new instruments now
routinely provide RMS capability. The cost of doing so has dramatically
dropped.
Primarily because average responders were so ludicrously bad.
They're only bad if you want to measure RMS. As far as bandwidth goes,
cheap averagers can be just as bad as cheap RMS circuits. Most do
handle 60 Hz pretty well.
Few meters will measure DC-coupled RMS, on the voltage or, pertinent
to this thread, current ranges.
John
John Larkin
The old hot-wire ammeters indicated RMS of AC+DC. Some of the thermocouple
type RF ammeters do it too. I always buy RF ammeters that I find at hamfests
just because they can do this. The construction of the RF ammeters sometimes
adds a small fraction of the applied current drop in series with the
thermocouple output, and these can't accurately measure RMS AC+DC. They will
often read backwards with applied DC of one polarity, and way too high with the
other polarity. The ones I covet don't have this problem, and will read
correctly with DC or AC (up to 65 MHz typically). I use them to measure
currents in switching supplies. The modern DVMs are often fooled by all the RF
flying around in a switcher, but the thermocouple RF ammeters aren't.
Another type of meter that will correctly read RMS of AC+DC is the moving iron
meter. These are often in the form of a panel meter, intended to be connected
to the secondary of a current transformer, and typically are 5 amps full scale,
even though the printed scale may be different. Bring a magnet near one of
these and get a reading, so keep magnets away. They can be had surplus quite
often for a good price. They aren't good for high frequency AC as are the RF
ammeters, but for line frequency work, they are quite handy.
I have a box full of flea-market thermal converters, which sort of
look like acorn tubes with flying leads. Inside is a heater and a
thermocouple. They were, maybe still are, used as ac-dc transfer
standards.
Fluke and somebody else still make thermal-transfer based bench DVMs,
very accurate and very expensive.
John
The Phantom
I thought your example of a "clean rectangular pulse" was a good example to
bring out the info the OP wanted without involving a lot of side issues. I just
happened to notice that there was another way to get power *in this particular
case* only. I thought it was interesting.
The point Phil made, that if a time varying current is delivering power to a
constant voltage drop, the simple average of the current is the number to use
rather than the RMS, is quite correct. But now we're off onto practical issues
and questions of personal experience, and I refuse to participate.
I also thought that Fred Blogg's post was the best "stick to the point" answer
to the OP's question.
LOL! That's for sure!
The Phantom
In another thread you said "...why not use a single fast (successive
approximation) ADC and then DSP the data? That way you could extract
anything and feature-itus it to your heart's content. And get superb
wideband AC accuracy."
I don't know if you saw my response where I said that I think that's what the
current crop of DMMs are, in fact, doing.
Fluke has a lot of specialty meters for measuring power quality that measure
and display everything you can think of. They display the harmonic magnitudes,
power factor, distortion, peaks detected. I'm sure they have a DSP core they
use in all these new instruments.
The Fluke 189, which is a few years old now, has a severe case of
feature-itus. I has wide AC bandwidth, it does RMS DC+AC on both current and
voltage, it measures capacitance, frequency, duty factor, peak voltage and
current (with slow and fast peak capture), can log measurements, can infrared
link to your PC, etc., plus all the usual stuff, and, it doesn't use a 9 volt
battery (thank you, Fluke). I think this kind of capability will be the norm in
all but the Radio Shack type meters.
Phil Allison
"John Larkin"
Don Lancaster
** Hang on here a mo.
An "average responding, DC reading" amp or volt meter has no high
frequency response issues.
A meter designed to respond to the average *RECTIFIED* value of an AC
waveform has that problem - along with most true rms meters ( thermal
ones can operate to GHz) and moving iron meters when measuring AC.
......... Phil
Steven Swift
Don Lancaster said:
Don Lancaster voice phone: (928)428-4073
Synergetics 3860 West First Street Box 809 Thatcher, AZ 85552
rss: http://www.tinaja.com/whtnu.xml email: [email protected]
Please visit my GURU's LAIR web site at http://www.tinaja.com
Hey, Don, you're probably the reason I went into electronics.
Thanks for all those wonderful construction articles over the years in
Popular Electronics. I still use some of the little test circuits I built
from your articles.
Have a great new year.
Steve.
