Ruby amp debugging help
electronoobz
Jan 14, 2012
226
i installed the ic and the jfet correctly.. there's a hiss and buzzing noise when im touching pin 2,1,8..
any clue?
Schematic?
The most probably reason is that you're amplifying hum that your finger is inserting into the circuit.
electronoobz
Jan 14, 2012
226
im doing it to check if it will have sounds but when im using the jack there's no sound amplified.. but again will sound if i touch the pin 2..
when im touching 1 and 8 (which is the gain) there's a lot of buzzing noise which means it is really working.. just doing it for check
Do you get the sound if you touch the gate of the jfet?
What is the voltage across the 3k9 resistor?
electronoobz
Jan 14, 2012
226
i remember asking you if i could use 2n5458 you said yes.. i really think that is not the problem.. the ic is working also.. so very sad because of this...
OK, so you hear the buzz when touching the input, but not when the input source is attached.
What is the input you're connecting it to?
Have you tried a capacitor in series with the input?
Is it possible you are using a mic that requires phantom power?
electronoobz
Jan 14, 2012
226
im using my guitar.. cant hear any sound.
my guitar electronics is fine.. i tested it in out power amp
Are you connecting the ground?
The idea is to answer ALL questions, not just the last one.
electronoobz
Jan 14, 2012
226
yes i did... caps series with the input?? not yet.. what value anyway? 100uf?
0.1 uF to 1 uF should be fine for testing.
electronoobz
Jan 14, 2012
226
So sad, bad luck today.. Bought wrong value
Can I use 4.7uF?? Which side for positive??
Yeah, sure. Connect -ve to the gate of the JFET
electronoobz
Jan 14, 2012
226
i tested my ruby mp with my multitester.. (volt tester) and put the first one to ground and the other one to every part
pin 2,3,4 has no voltage (3 and 4 is conencted to ground)
Relayer
Dec 15, 2012
39
I hope you realize you're using an RF JFET, not suited for audio.
Regards,
Relayer :D
14,485
Regards,
Relayer :D
Hmmm, yeah that thought crossed my mind too.
The lowest freq's I have used them on have been between 200 - 500kHz
for receiving aeronautical NDB beacons
I'm not sure how they perform below that ... maybe no problem ??
electronoobz
Jan 14, 2012
226
but i asked steve a long time ago about that.. i also told him that im making an amp.. he said 2n5458 is ok
14,485
but are you using that one or the MPF102 as shown in the cct diag ??
