Rich Grise
- Jan 1, 1970
- 0
Well, as long as you know who it's from, you still have the power to"Slaughter your family now - Satan commands it!"
use your common sense and mutiny. ;-)
But - did the noise go away?
Rich
Rich said:Well, as long as you know who it's from, you still have the power to
John said:I read in sci.electronics.design that Dirk Bruere at Neopax
electronic brain stimulator', on Thu, 23 Sep 2004:
Yes, in my limited experience. I have mild, intermittent 'tonal'
tinnitus, hardly any more than normal 'ringing ears', except that it
often persists for several hours.
Perhaps a decade or more ago folks sharing experiences with tinnitus
stumbled on the "triggering" idea, where many folks who have this
problem can figure out what sort of sounds can bring it on. Often
this is rather specific. But nobody, other than one guy who made
himself a lot of money "training" you to not care about the tinnitus,
seems to have reported any success with finding a way to trigger it
back off. And I'll promise you that I've spent a lot of months
looking for clues.
That's about it.
Free Will is an illusion...
[see other thread for references]
And how frequency stable is the tinnitus?
Dave said:In my case, it's not so much a tone, as narrow white noise, around a
frequency.
It might be changing, but not that I notice.
I don't know how you'd address that - do you mean, something in the ear,Blood in veins/capilliaries? Can you hear the heartbeat?
BTW, is it possible to check whether a noise really exists or whether it's
'internal'?
Dirk Bruere at Neopax said:Can sound at about the same frequency cause interference effects?
John Woodgate said:
John Woodgate said:Yes, in my limited experience. I have mild, intermittent 'tonal'
Dirk Bruere at Neopax said:And how frequency stable is the tinnitus?
Rich Grise said:Thanks for the feedback. It would have been cool if it had "worked,"
but science is, after all, science. So my hypothesis has encountered
its first counterexample in the first actual experiment - I guess
I won't go around trying to tout my new "cure"!
Thanks again,
Rich
Dave VanHorn said:In my case, it's not so much a tone, as narrow white noise, around a
frequency.
Dirk Bruere at Neopax said:Blood in veins/capilliaries? Can you hear the heartbeat?
'internal'?
it's 'internal'?
literally vibrating mechanically? Cilia move, after all. You'd need an
awfully sensitive mic, I'd think.![]()
And if that is the case, it'd be worth looking into, if somebody wants
to spring for the research.
Somebody mentioned the ear actually generating sound earlier, and I
thought, that would bring new meaning to "talking through his hat"! ;-)
Nope, the amplitude, if it varies, does so very slowly.Blood in veins/capilliaries? Can you hear the heartbeat?
'internal'?
I read in sci.electronics.design that Rich Grise <[email protected]>
It's the basilar membrane within the cochlea that vibrates. You need a
quiet room, but an ordinary electret mic placed close to the ear is
quite good enough.
Think about a section of the basilar membrane as a quartz crystal or
ceramic resonator. The local inner hair cells act as the input
electrode, and the local outer hair cells act normally as a gain
control, creating the logarithmic response of the ear to sound pressure.
Their activity is not locally-controlled: the signals go via the
auditory nerve to the auditory cortex in the brain and back again.
Damage to the outer hair cells can result in gain control being lost
('recruitment'), and it seems that in addition an actual signal-
frequency positive-feedback loop can be set up, so that the basilar
membrane is forced to vibrate even with no input.
[What happens, conjecturally, is that the signals from the outer hair-
cells go to a 'diode detector' before passing to the cortex, which
processes the resulting gain-control 'voltage'. The damage corresponds
to the filter capacitor of the detector going open-circuit, so that
instead of 'd.c.' being passed to the cortex, signal frequency is
passed, and is passed back to the hair cells, thus creating the feedback
loop.]And if that is the case, it'd be worth looking into, if somebody wants
It's been done, but of course 'more research is needed'.Somebody mentioned the ear actually generating sound earlier, and I
If you have a hat that comes down over your ears, yes.
Good description but leave the cortex out of it the control mechanism;
it's the brainstem.
John said:I read in sci.electronics.design that Rich Grise <[email protected]>
wrote (in <D1L4d.12131$464.8838@trnddc01>) about 'safe electronic brain
stimulator', on Fri, 24 Sep 2004:
quite good enough.
What makes it vibrate?
Muscles?
Normally the incoming sound. It goes through an impedance transformation
in the middle ear to match it to the fluid in the cochlea.
In the case of spontaneous sound emissions, the hair cells seem to
instigate the vibration. I don't think you could say there are any
'muscles' in the conventional sense in the cochlea. The cellular
structure is very complex and is not completely resolved to the
functional level even now.
Dana Raymond said:My original post about safely stimulating my brain really had more to do
with the ridiculousness of actually trying to interfere with my brain
function. Even if I thought complete due diligence was exercised with a
project like this, I would still run away, as fast as I could, from the
experimenters if they came at me with the thing! LOL
