Sallen Key Low Pass Filter, bandpass filter
Maglatron
Jul 12, 2023
2,025
so I added some up on mouser, and chose the capacitors as film type they come to £130.50 Is that too much???
bertus
3,877
Most times film capacitors will have a better quality as ceramic capacitors.
Bertus
Maglatron
Jul 12, 2023
2,025
in this envelpe detector are the cap values in uf
bertus
3,877
That is a very complicated detector.
A simple diode with a capacitor to ref might even do the trick.
Bertus
Maglatron
Jul 12, 2023
2,025
ok thats fine it said precision envelope detector can you recommend a setup please will that be generic for all the filters perhaps a good youtube video maybe
Maglatron
Jul 12, 2023
2,025
I found this for RC selection with known carrier frequency and base frequency what are the differences between the two
bertus
3,877
Have a look at the following picture for the effect of the RC on the shape of the envelope:
The fine signal shape is the audio signal. The thick line is the created envelope.
You could try 100 nF with 1 MOhm for RC and see how it behaves.
Bertus
Maglatron
Jul 12, 2023
2,025
Something just occured to me, can you simulate a 45hz signal that varies in amplitude in spice, I'm sure you can, then how do you do that?
Maglatron
Jul 12, 2023
2,025
Nice one bertus, can you have one wav file of 45hz with varying ampitude for say a minute?
I will read now!
Maglatron
Jul 12, 2023
2,025
ok got the program I also use reaper how do you setup a frequency of 45Hz with Audacity?
bertus
3,877
In the menybar there is generate. You can create several types in there.
With chirp you can create a frequency shift over time.
That way you could test the behaviour of a filter.
Bertus
Maglatron
Jul 12, 2023
2,025
Bertus
ok good idea, but first off I want to vary the amplitude of the 45z so that its not a constant volume, this is because I believe that it will be better for designing the envelope detector settings of the cap and resistor
