yes Ante, something did go wrong it was U2, I replaced it with another and it worked, and I tried removing the diode again and it worked find like you said it would ;D. Removing the diode didn't make any difference, except for having one less component which is good. The output from U1 is 2.43v to 3.62v. I tried using an electromagnet from a relay, and its influence on the Hall affects sensor was a little better than half that of the influence of the magnet. That's not all that good, the electromagnet that I used is about twice the size of what I wanted to use. So I may have to try to use a standard magnet. I wanted to use an electromagnet so I could very it's, strength giving me more opportunity for collaboration
ante, just to be sure, yes I was pulling your leg, in regards to it being your fault something went wrong ;D. When you suggested to remove the diode, and I found problems after I done this, I hope you don't think I was pointing the finger at you because something went wrong ???, I would never do that
, even if you did make a mistake on a suggestion and everything went up in smoke. I was just trying to use some good old Aussie humour, I hope you took it the right way, mate ;D ;D.
