Einstein
- Jan 1, 1970
- 0
PS, if you don't want to use an electrical circuit, use a magnet on theEinstein said:Look at placing a plastic encapsulated bar magnet in a flaring high
pressure plastic pipe with a magnetic reed switch above the magnet and
against the pipe. Flow causes the magnet to rise, actuating the reed
switch. Put the reed switch in series with a relay actuation coil. No
issues with corrosion and very simple. As with any pumping application,
size a foot strainer to ensure particles will pass by the magnet in the
flaring tube. The flaring tube can be an adaptor from 3/4" to 1", the
magnet diameter is sized to have sufficient restriction in 3/4" tube to
have the liquid flow cause the magnet to rise into the bigger cross
section tube above with flow.
outside of the pipe, located on a pivoting arm, so that the outside magnet
follows the movement of the inner magnet. The position of the outside magnet
will indicate whether you have fluid flow or not.
