Simple Overvoltage protection
Status
Not open for further replies.
David Gregory
Nov 5, 2016
7
I have a 13.8v, 30 amp power supply that is over current protected, but not over voltage protected.
Am I correct in thinking that a simple zener diode across the outputs, and an in-line fuse is all I'll need to have a crude, but effective over-volatge protection circuit?
If I use a zener of 14.4v or there abouts, if voltage exceeds this level, the zener will breakdown and short out the PSU's output, and blow the fuse.
My question is, for a 30 amp supply, what zener will I need to survive the time it takes to blow the fuse, considering it will be drawing 30 amps approx.
I hope I'm making sense :)
David
Colin Mitchell
Aug 31, 2014
1,416
Why would the power supply go over voltage????
What about putting a "stopper" on the control knob ????
David Gregory
Nov 5, 2016
7
Failed Voltage regulator? Failed, or dirty potentiometer? (it has variable output). I'm assuming it must be plausible to go over voltage, or why else would a great many PSU's have over voltage protection?
Thanks BobK.... A crowbar circuit looks simple enough. I was just looking for something as simple as possible to keep from overly modifying the PSU.
Samodelkin
Nov 16, 2022
Let's bump the thread )))
I would like to add overvoltage (not lightening, but N wire disconnection) protection to the apartment board. Currently I have such spike protection (Uc=275V 220V network) installed:
L and N connected to upper side, and PE to bottom.
So I see following options (besides to purchase some relay and replace board for bigger one):
1) Swap PE and N, thus varistor will limit L-N voltage, and will cause overload switch activation, disconnecting power.
2) Add low voltage varistor (10-25V) between N and PE.
3) Add SSR like
1PC-10A-25A-40A-60A-AC-AC-Single-Phase-Solid-State-Relay-AC-SSR-SSR-10AA.jpg_220x220xz.jpg_.webp
with input connected to N-PE, and output with resistor 2-4 kOm between phase and PE, thus causing residual-current device disconnect power.
What do you think?
Status
