Simple plan - will it work?
Bdyne
I am installing a 115VAC cooling fan for my computer. The fan will be
mounted in an enclosure feeding 3" diameter flex hose to the computer
case. I will be using a 5 VDC signal from a fan connection on the
motherboard to close a small radio shack relay (5VDC - 120VAC) and
start the fan. Is it this simple or am I forgetting something? I
don't want to burn the house down!
petrus bitbyter
Generally speaking the idea will work. But I can imagine some things you'll
have to check.
- Check the current rating of the contacts of the relay. (Just to stay on
the safe side.)
- Check the 5V control voltage you want to use. If it is directly connected
to the 5V power you will have no problem but when it is switched somewhere,
the switch (a transistor for instance) may not be able to provide the extra
current for the relay.
When you connected the fan and the relay, check the circuit, particularly
the relay when it switches the fan off. If there's a heavy sparking at the
contacts you may suppress them by placing a capacitor parallel to the
contacts. I guess a 1nF/250VAC will do.
petrus
K
Keith R. Williams
have to check.
the safe side.)
Don't forget the free-wheeling diode across the relay coil (at the
driver end of the cable).
Don Bruder
Ummm... Why?
Perhaps I'm daft, but isn't a freewheel diode only needed in cases where
a permanent magnet type (which almost always means DC-powered) motor is
being controlled? Unless I've misunderstood things really badly, your
typical AC "fan motor" type doesn't act as a generator/alternator when
freewheeling down after power-off, since there's no juice on the stator,
therefore there's no magnetic field to be cutting/cut by the windings of
the rotor, which renders it functionally nothing more or less than a
flywheel. (Albeit it fairly poor one, since they're usually pretty light)
Conversely, cutting the juice to a PM-type motor DOESN'T "turn off" the
magnets that make up the "stator", so the magnetic lines of force are
cutting/being cut by the windings of the rotor, producing juice as long
as the rotor continues to spin after power-off.
K
Keith R. Williams
Ummm... Why?
It's not the motor that's in question.
Unless I've missed the whole point here, he wants to pick a 5VDC relay
coil to control a 115V fan. Since the relay coil (and the wire between
the the driver and the coil) has significant inductance, a free
wheeling diode is needed to clip the transient when the driver turns
off. ...otherwise the driver goes to driver heaven and he's out a
motherboard.
Lord Garth
Don Bruder said:
Ummm... Why?
The poster said to put the diode across the RELAY COIL not the motor.
When the relay de-energizes, you will create a reverse EMF. The diode
will shunt that so as not to possibly damage the driver transistor.
Don Bruder
D'oh! Musta missed that part. Somehow, for some reason, I was thinking
that the poster was saying put the diode across the MOTOR side of
things, not the relay coil side. In that case, I withdraw the question.
Don Bruder
motherboard.
Now that it's been pointed out to me that you were saying "put it across
the relay coil", you're 100% correct. I must have missed that when I
read the message I replied to. Had I seen/understood that as your
intent, I would have been completely in agreement, and wouldn't have
bothered to post my response. Chalk it up to a brain-fart, I guess.
Bill Bowden
Don Bruder said:
Ummm... Why?
The diode goes across the relay coil. The coil is a inductor
and produces back emf of L*di/dt which is a bad thing without
the diode.
-Bill
petrus bitbyter
You're right, I should have mentioned it. The 5V power will not be harmed,
but if the control voltage is switched by a transistor you can easily blow
it (the transistor) if you don't use a free-wheeling-diode.
petrus
Bdyne
You guys kind of lost me (noob)- but I'm sure glad I asked here before
cooking my new mobo! Thank you all very much.
I understand what a diode is - like a check valve. If I look at the
bottom of the relay I have 2 contacts for the DC and 3 for the AC.
Physically where in the circuit are you putting the diode? And is the
diode one of those resistor-looking ones or the three wire ones (I
would guess the 2 wire).
Again thanks for helping me NOT fry my new board.
K
Keith R. Williams
Since the current in an inductor (the relay coil and long wire) cannot
change instantaneously, when the driver transistor turns off the
current will try to go somewhere. Without the freewheeling diode there
is no other path so the voltage rises until it can go somewhere. Zap,
your off transistor is no longer off (if it's anywhere to be found. ;-)
With the freewheeling diode, the current flows through it into the 5V
supply, effectively shorting out the inductor. Of course when the
driver is ON the diode is backwards biased, so it's not in the picture.
+5V
C| o /
relay C| /
C| ./
| o
+5V |
- Freewheeling diode |
| long wire
-| driver
created by Andy´s ASCII-Circuit v1.22.310103 Beta www.tech-chat.de
You'd better check the current rating of the driver too. ...and please
be careful with the 120V circuit! It'll do some damage to your board
too (and you).
Rich Grise
Just a nitpick, but it should be:
+5V
| C| o /
Freewheeling diode - relay C| /
^ C| ./
| | o
| long wire
-| driver
Cheers!
Rich
John Popelish
+5V
| C| o /
^ C| ./
| | o
| long wire
-| driver
Since we are picking nits, you should keep in mind that wiring has
inductance, too. The cleanest way to use the diode is at the switch
as follows:
+5V
| C| o /
| relay C| /
| C| ./
| two | o
+5v | long | |
| | wires |
-| driver
0v
Rich Grise
Yeah - you've got all that inductance in the wire in series with the
inductance in the relay coil, so you get an even bigger spike! (and
more concomitant radiated noise)
Cheers!
Rich
K
Keith R. Williams
It's better than frying the driver! We had several IBM 3033s
catch fire because of exactly this problem (inrush limiters stuck
on). Customers weren't impressed and management was *not* amused
at this little slight. Especially so, since the drivers had the
diodes built=in, but the designer didn't want to wire 48V on the
card and instead mounted diodes on the contactors. No, the free-
wheeling diode goes on the driver. After all, it's not there to
protect the relay coil. ;-)
