Robert Baer
- Jan 1, 1970
- 0
Depends on your definition / configuration.George said:If I have a source terminated transmission line (think of a length of
coax with a 50 ohm resistor to ground at the source.) and it goes into
an open circuit. (say into an unterminated 'scope input.) Then is
there a reflection from the unterminated end? And if so, the reason
that there is no ringing observed is that the source termination soaks
up the return signal. Or does the source termination make the
transmission line 'happy' regardless of what's on the other end?
George H.
Config #1: generator is 50 ohms and you consider that as "source
termination" --> signal bounces back, one sees it at generator.
Config #2: generatro is 50ohms, then a 50 ohm resistor ("source
termination") in series to drive coax -->signal bounces back and all
looks kosher at coax source end.
