Sony BVW35 BetacamSP portable drawing excessive supply current.
  • Thread starter Colin McCormick
  • Start date
Colin McCormick
I recently purchased a BVW35 (NTSC) portable BetacamSP recorder on
eBay (item 260191946198). I also bought a power cable cable (eBay item
280195546810) which has ground pin 1 and 12V on Pin4. The machine powers
up OK, but draws a hefty 2A and makes a whining sound. This doesn't seem
right. Eject does not operate: Right takeup spool splins clockwise for a
moment but that is all. The loading ring is already unloaded (and if I
wind it in a bit, it properly unloads again).
Some more detail: The 2A is drawn at all times that the unit is switched
on, unless the PB/EE switch is in the SAVE position, in which case it is
only drawn for the time it is trying (and failing) to eject. Conclusion:
When the deck is powered up, something is taking 2A. Perhaps a stalled
motor. Switching off teh TBC does not change the drawn current, nor
panel illumination, so eliminating those items.
Anyone have diagrams of this machine? Mine is the BVW35 but manuals for
the BVW35P would be fine for this problem.
I'm in the UK and needed an NTSC BetaSP player.
Thanks for any help. Please copy your reply to:
[email protected]
Colin (www.video99.co.uk)
