spec out low power bjt
panfilero
High beta at low current. BCX70K maybe. Make sure you don't zener the e-b
junctions.
Maybe you can use the UniShot circuit. It's like a 1-transistor monostable, sort
of. You can build long strings of them. Fun.
https://dl.dropboxusercontent.com/u/53724080/Circuits/Timing/UniShot.JPG
John Larkin Highland Technology Inc
www.highlandtechnology.com jlarkin at highlandtechnology dot com
Precision electronic instrumentation
Picosecond-resolution Digital Delay and Pulse generators
Custom timing and laser controllers
Photonics and fiberoptic TTL data links
VME analog, thermocouple, LVDT, synchro, tachometer
Multichannel arbitrary waveform generators
thank you sir,
so on my circuit, looks like my only current flow will be through R3, whichif I pull it up to 3.3V and use a 10k gives me about 330uA going through it, where do I start to push my limits here, if I have a 100k I end up at 33uA, is this pushing it... I'm just wondering how to evaluate this... 10k isprobally fine for what I'm doing but I'm just curious about how low I could bring my current... does the high beta take care of this?
Is the UniShot non-retriggable?
Bill Sloman
I'd like to make a low power one shot circuit, I'm planning to use a monostable oscillator to get my one shot functionality, but I was wondering what NPN transistor specs do I need to look for in order to get the lowest power circuit out of this? The circuit I'm building is below
link:
http://pcbheaven.com/scripts/imagep...ages/images/transistorcircuits_1235488122.jpg
Years ago (July 2008), we had a discussion here on making a low power oscillator -"micro power square wave oscillator". The base-emitter capacitance of the transistor involved turned out to be the feature that determined the current drawn at any sensible frequency, and the palm went to wide-band transistors with Ft's of 5GHZ and higher.
I think I posted an LTSpice circuit using a pair of BFR92 transistors to create a 100kHz oscillator. Jeorg went one better with BFP620's (which are more expensive and even more prone to oscillate, but faster). You need a "base-stopper" - something of the order of 33R in series with the base connection - to stop this kind of part from oscillating at few GHz, and you need toremember that base-emitter break-down voltage is only 2V in this kind of transistor.
panfilero
Years ago (July 2008), we had a discussion here on making a low power oscillator -"micro power square wave oscillator". The base-emitter capacitanceof the transistor involved turned out to be the feature that determined the current drawn at any sensible frequency, and the palm went to wide-band transistors with Ft's of 5GHZ and higher.
I think I posted an LTSpice circuit using a pair of BFR92 transistors to create a 100kHz oscillator. Jeorg went one better with BFP620's (which are more expensive and even more prone to oscillate, but faster). You need a "base-stopper" - something of the order of 33R in series with the base connection - to stop this kind of part from oscillating at few GHz, and you need to remember that base-emitter break-down voltage is only 2V in this kind oftransistor.
thank you sir, I'll look into these
Jasen Betts
On Thu, 09 May 2013 14:08:07 -0700, Jim Thompson
[snip]
The above link has been re-posted, with a fix for the glitch... easy
for those of us who actually understand transistors >:-}
...Jim Thompson
Those without "limited skill set" are invited to muse over WHY the
base resistors I added get rid of the glitch sensitivity.
It forms a low pass filter with the base capacitance
Another way to fix it is to increase the collector resistors a bit.
if the transistors aren't saturating you've got a high pass filter
with unconstrained gain if they are you have sub-unity AC gain,
and thus should be safe.
I had to reduce the collector resistors in LTSpice else I didn't get
the glitches you were seeing
Jasen Betts
On Thu, 09 May 2013 15:14:49 -0700, Jim Thompson
[snip]
http://www.analog-innovations.com/SED/Oooops.pdf
...Jim Thompson
Nope. It has to do with the base input characteristics.
Are you suggesting suicide bias? But you idea _will_ work, IF you pad
the emitter with a resistor and then use a divider to set the bias
rather than a single resistor... then you basically have a class-A
stage.
I'm not familiar with that term ( googling "bipolar suicide bias" was
no help :^) )
I'm seeing a failure mode where the voltage source beeing is pushing a pulse
through tee B-C junctions of the transistors when it goes high, adding
emitter resistors but leaving the base connected to the capacitor will
likely make that glitch worse.
I'm seeing it run slightly faster. with increased input impedance of
each stage the collector waveform output of the intermediate stages
is squarer. that's about all.
I ran it with TStepMax = 10ns
10ns made no diference. neither did 1ns, except for increasing the run
time.
I dont see the glitches like in your PDF until I reduce the collector
resistor to about 1K
Version 4
SHEET 1 940 680
WIRE 128 16 -32 16
WIRE 224 16 128 16
WIRE 320 16 224 16
WIRE 416 16 320 16
WIRE 512 16 416 16
WIRE 608 16 512 16
WIRE 704 16 608 16
WIRE 800 16 704 16
WIRE -32 32 -32 16
WIRE 128 32 128 16
WIRE 224 32 224 16
WIRE 320 32 320 16
WIRE 416 32 416 16
WIRE 512 32 512 16
WIRE 608 32 608 16
WIRE 704 32 704 16
WIRE 800 32 800 16
WIRE 48 128 16 128
WIRE 128 128 128 112
WIRE 128 128 112 128
WIRE 224 128 224 112
WIRE 240 128 224 128
WIRE 320 128 320 112
WIRE 320 128 304 128
WIRE 416 128 416 112
WIRE 432 128 416 128
WIRE 512 128 512 112
WIRE 512 128 496 128
WIRE 608 128 608 112
WIRE 624 128 608 128
WIRE 704 128 704 112
WIRE 704 128 688 128
WIRE 128 144 128 128
WIRE 320 144 320 128
WIRE 512 144 512 128
WIRE 704 144 704 128
WIRE 224 192 224 128
WIRE 224 192 208 192
WIRE 416 192 416 128
WIRE 416 192 400 192
WIRE 608 192 608 128
WIRE 608 192 592 192
WIRE 800 192 800 112
WIRE 800 192 784 192
WIRE 16 208 16 128
WIRE 128 240 128 224
WIRE 144 240 128 240
WIRE 320 240 320 224
WIRE 336 240 320 240
WIRE 512 240 512 224
WIRE 528 240 512 240
WIRE 704 240 704 224
WIRE 720 240 704 240
WIRE 224 288 208 288
WIRE 416 288 400 288
WIRE 608 288 592 288
WIRE 800 288 784 288
WIRE -32 304 -32 112
WIRE -16 304 -32 304
WIRE 16 304 16 288
WIRE 16 304 -16 304
WIRE 224 304 224 288
WIRE 224 304 16 304
WIRE 416 304 416 288
WIRE 416 304 224 304
WIRE 608 304 608 288
WIRE 608 304 416 304
WIRE 800 304 800 288
WIRE 800 304 608 304
WIRE -16 320 -16 304
FLAG 800 192 out
FLAG -16 320 0
SYMBOL npn 144 192 R0
SYMATTR InstName Q1
SYMATTR Value 2N3904
SYMBOL res 208 16 R0
WINDOW 0 41 29 Left 2
WINDOW 3 37 55 Left 2
SYMATTR InstName R1
SYMATTR Value {R_c}
SYMBOL res 112 16 R0
WINDOW 3 35 76 Left 2
SYMATTR InstName R2
SYMATTR Value {R_b}
SYMBOL cap 112 112 R90
WINDOW 0 0 32 VBottom 2
WINDOW 3 32 32 VTop 2
SYMATTR InstName C1
SYMATTR Value 1n
SYMBOL npn 336 192 R0
SYMATTR InstName Q2
SYMBOL res 400 16 R0
SYMATTR InstName R3
SYMATTR Value {R_c}
SYMBOL res 304 16 R0
SYMATTR InstName R4
SYMATTR Value {R_b}
SYMBOL cap 304 112 R90
SYMATTR InstName C2
SYMATTR Value 1n
SYMBOL npn 528 192 R0
SYMATTR InstName Q3
SYMBOL res 592 16 R0
SYMATTR InstName R5
SYMATTR Value {R_c}
SYMBOL res 496 16 R0
SYMATTR InstName R6
SYMATTR Value {R_b}
SYMBOL cap 496 112 R90
SYMATTR InstName C3
SYMATTR Value 1n
SYMBOL npn 720 192 R0
SYMATTR InstName Q4
SYMBOL res 784 16 R0
SYMATTR InstName R7
SYMATTR Value {R_c}
SYMBOL res 688 16 R0
SYMATTR InstName R8
SYMATTR Value {R_b}
SYMBOL cap 688 112 R90
SYMATTR InstName C4
SYMATTR Value 1n
SYMBOL voltage -32 16 R0
WINDOW 123 0 0 Left 2
WINDOW 39 0 0 Left 2
SYMATTR InstName V1
SYMATTR Value 5
SYMBOL voltage 16 192 R0
WINDOW 3 -10 135 Left 2
SYMATTR InstName V2
SYMATTR Value PULSE(0 5 100u 100n 100n 600u 1 1)
SYMBOL res 144 240 R180
WINDOW 0 -20 96 Left 2
WINDOW 3 -44 63 Left 2
SYMATTR InstName R9
SYMATTR Value {R_f}
SYMBOL res 336 240 R180
SYMATTR InstName R10
SYMATTR Value {R_f}
SYMBOL res 528 240 R180
SYMATTR InstName R11
SYMATTR Value {R_f}
SYMBOL res 720 240 R180
SYMATTR InstName R12
SYMATTR Value {R_f}
TEXT -34 -8 Left 2 !.tran 0 2m 0 10n
TEXT 160 -16 Left 2 !.PARAM R_b=100k
TEXT 336 -16 Left 2 !.PARAM R_c=1k
TEXT 488 -16 Left 2 !.step PARAM R_f 0.00001 10000.00001 10000
