Pioneer Spec 4 outputs
mrmodify
Feb 13, 2010
164
Hi all,
I am working on a Pioneer Spec 4 amplifier.
I think I have it repaired but I have not installed the 4 output transistors as of yet.
My question is can I power the unit up with the output transistors removed?
Martaine2005
May 12, 2015
5,318
Most of the time, it’s not necessary to power it up.
If a short was present with the transistors in and no short with them removed, it’s fairly safe to replace them and power it up.
I always use current limiting bulb (dim bulb tester) to double check on first power up.
mrmodify
Feb 13, 2010
164
Thanks Martainr
I had several burnt, shorted and open components. I replaced all those and checked the rest of the components on the board with testers.
I am using a DBT and have the outputs removed.
Currently I have 2 transistor on the negative power side of the board that will get hot after about 20 seconds after powering up. I am not sure if I have a problem or if its because of the missing outputs. The positive side does not heat up.
Martaine2005
May 12, 2015
5,318
Very difficult to say without seeing the circuit.
Are the required voltages present?
Delta Prime
Jul 29, 2020
2,996
  • Pioneer-Spec4-pwr-sm.pdf
mrmodify
Feb 13, 2010
164
This is what I came up with. The right channel operates fine. These voltages are in red. The left channel is the one I am working on. The outputs are removed and Q9 & Q11 will get warm after about 15 seconds.
[Mod edit: image rotated and cropped for better readability]
WHONOES
May 20, 2017
1,242
Can you show us a complete circuit of the power amplifier section including the output transistors and rotate it 90 degrees?
mrmodify
Feb 13, 2010
164
Yes sir, let me know if this is not good.
WHONOES
May 20, 2017
1,242
Disconnect the output transistors and then measure the output voltage with respect to 0V.
mrmodify
Feb 13, 2010
164
Hi all,
Update,
Thank all of you for the help. I did power the unit up on a DBT and everything was fine except for the voltage on Q11 & Q10 emitter.
Installed the outputs and powered up again and all voltages were fine. Q11 went from -4vdc to -.6 vdc. Q10 went from 4vdc to .6vdc.
Took amp off of the DBT and powered up on line voltage and again unit operated fine.
Again thanks for the input you guys gave me!
14,317
I beg your pardon if the question sounds stupid: What is a DBT?
mrmodify
Feb 13, 2010
164
No such thing as a stupid question in my mind.
DBT is a dim bulb tester.
It is nothing but a incandescent bulb wired in series with the equipment being tested. It limits the current depending on the size of the bulb. A
100 watt bulb on 120vac will only allow 1.2 amps of electricity for the connected equipment.
If you have a shorted component it keeps from letting the smoke out.
