Stage Line 500W amp repair project
WHONOES
May 20, 2017
1,242
I'm busy this eve but, if you can wait till tomorrow I will draw a sketch for you.
bikemech
Oct 23, 2014
456
Thank you and thank you for your time, that would be good, but its ok for now, enjoy your evening and i will do some research over the weekend and try to understand opams and how they work, and maybe understand a bit better,
Pete
WHONOES
May 20, 2017
1,242
See attached OPAMP pinout sketch. The spot indicates pin 1 sometimes they will have a notch at the top instead.
  • DUAL OPAMP PINOUT.pdf
bikemech
Oct 23, 2014
456
aahhhh, i see thank you for that, i had it completely wrong, i thought it was like my sketch,
bikemech
Oct 23, 2014
456
is this because there duel, basically 2 amps in 1 IC, i did see some documentation where they were 4 in 1
bertus
3,875
The opamps are this way connected in the housing:
Bertus
bikemech
Oct 23, 2014
456
So this is what i have ended up with, looking at it now i think i made it hard for myself, anyway almost there20210123_184223.jpg
bikemech
Oct 23, 2014
456
I basically coppied the drawing, didnt take in to account there dual, doh !!!
WHONOES
May 20, 2017
1,242
Never mind. The first step is always the hardest.
Do you have any more veroboard and can you get the sockets off without damaging them?
WHONOES
May 20, 2017
1,242
Yes but, it might be easier to take all components of and start again.
The best way for you to attack it is draw a grid representing the hole and strips of your veroboard and then plan out component placement before mounting any bits.
