GC
- Jan 1, 1970
- 0
Here I am again with more camera questions....
We have a PTZ camera on a pole, running off 24volt AC power supply....
We use the same type of power supply and cabling for all of the same PTZ
cameras....
At the power supply end, I have 25volts unloaded, then 24 volts when loaded
(Camera and housing attached)
On the camera end, I have almost 25volts..... but when we put the cameras
on, the voltage drops to 17 volts.....
We measured the voltage at the bottom of the pole... 17 volts..... but back
at the power supply still 24 volts....
Somehow we get a drop of about 7 volts on the cable run, which appears to be
quite a lot when its only about a 20 metre run. We don't get this happening
for longer runs than this.....
So it looks like the cable.....
What could cause a drop this large?? The cabling in run in conduit under
ground.
If the conduit was full of water could that cause this???
cameras....
ground.
