How so? I thought the fundamental limitation of DC was that it was
harder to transport over long distances (even at 500kV which is what I
think the big DC interconnects use).
http://www.abb.de/cawp/gad02181/34e09dbfd8144050c1256f9d00507231.aspx
Depends on voltage. What is true at 100kV is not necessarily true at
1000kV.
Recall that for a DC power line losses are current times resistance
squared, and that power transmitted is current times volatage.
So, as you raise voltage you get a lowering of losses. A 1,000kV line
has 1/10th the resistance losses per unit power as a 100kv line.
AC on the other hand because it is constantly varying has EMF
radiation along the line. This isn't a lot over short distances at
60HZ, but adds up over long distances.
The results when you carry out the engineering is that at 500kV for
example, an AC line loses more power if its over 600 km long than a DC
line. At 10,000kV you should be able to transmit power efficiently
around the world. If such things become possible, it would allow us
to build a powernet to rival the internet.
I know they do HV DC mains grid interlink in Japan, but that is
because the country has 50Hz and 60Hz power grids in different parts
of the country. Why do US utilities do DC interlink on a single
frequency?
That's another advantage certainly. And one reason DC lines are used
to tie the California grid with the rest of the US across the
Continental Divide. But Edison and Westinghouse's famous talk on the
advantages of AC - while accurate for 120 V lines - are not accurate
for HVDC lines. And since today's HVDC voltages were impossible in
the 1890s, we can't even say Edison and Westinghouse were wrong in
their choice in that era.
The size of the USA compared to the wavelength of 60Hz is not
negligible, but it doesn't seem excessive either.
Ultra-HVDC should make intercontinental power transmission possible.
It will remain infeasible for AC due to EMF losses. Also, unipolar
transmission is an interesting way to reduce costs in electron
gathering systems among dispersed DC sources. (HVDC lite)
Indeed. And there is an obvious conclusion.
Not at all.
Please consider the practical difficulties of taking a variable output
solar generator that varies its output in response to season, weather
and time of day operating with Direct Current and connecting that
source reliably to a grid of Alternating Current loads. When you do
large-scale intertie studies, something more than charging car
batteries,then you have diseconomies of scale that suggest $2 per watt
on the first go round, that over time and with experience will likely
drop to $0.70 per watt. At these prices your costs rise to $0.06 per
peak watt and tend toward $0.02 per peak watt.
Furthermore, since demand for energy exists when lighting conditions
are poor,or light is non-existent, then you can't provide 100% of your
power by direct intertie. This mean you cannot take control and
dominate the market. Which means you're sucking hind tit as a
business. Which means its not the way to enter the market.
The way to enter the market is to first get your primary costs down,
then, to make synfuels with solar hydrogen, and sell them on a scale
that permits you to achieve your costs. THEN sell hydrogen to
conventional generators, THEN sell electricity directly where
appropriate (once the intertie program I outlined elsewhere is
completed) - in any event, in developed nations, remote users and off-
grid applications will always be a tertiary market. Not so in less
developed nations, or developing nations. But those nations don't use
much energy anyway, and so they're at best secondary.
Bottom line, it is very efficient to use electricity directly. It is
not capital efficient or market wise. Which are important factors
when building a business.
For the record I have had conversations with AEP, Southwestern, and
First Energy about doing joint ventures. I did not obtain the sort of
relationship I sought, and so things didn't go anywhere. They did not
wish to enable me to dominate the energy business, which is my goal.
Those who buy gasoline on forward contracts could care less about how
I get the gasoline I sell them, or what it means to other producers.
So, that's what I did.
There have been a few impressive solar concentrators. Largely for
smelting exotic materials research and the odd one can do superheated
steam generation too.
But given the expense of refined silicon for high efficiency solar
panels it seems worthwhile to at least double the incident solar flux
onto them by using mirrors. It makes the wind loading worse of course.
But mirrors are cheap and solar panels expensive (even more so when
you have to worry about keeping them weatherproof).
But unless you have advanced optics of the type I've briefly sketched
here, you have other costs. I used molded PET plastic to make faceted
mirrors that are 4' x 4' and only a few inches thick. Vacuum coat the
PET on the back with aluminum, and its 98% reflective. Mold EPS in
the same shape, slight interference fit, and insert in the coated
plastic pan, after painting the backside to keep it from oxidizing,
and you have a highly reflective, highly stiff and stable mirror
system. Put in a few lightweight aluminum stringers, and you can
build big lightweight arrays that you attach to a space frame of any
size. Focus light to a point - but then depending on the degree of
concentration, you've got to point the thing, and the accuracy of THAT
starts adding to the cost. Especially when you intall it in a windy
location.
If someone can make plastic semiconductor based photovoltaic cells
that are chemically stable under sunlight then the economics could
shift,
That's a possibility. But another is CPV- concentrated photovoltaics
- which is what I'm doing. With an appropriate optical bandpass, and
proper electronic and optical structures - and liquid filled lens
medium with the focal point INSIDE the lens, and the PV device passive
cooled by circulating fluid in the lens itself - I reliably operate at
1,000x solar intensity and even $1 per square inch silicon doesn't add
much to total system costs.
but for the moment solar power is best at doing hot water
