W
[email protected]
- Jan 1, 1970
- 0
Nice. Then you wouldn't mind sharing the information (since, after
all, that is the purpose of a patent). Numbers please!
If i were a hard-ass i'd say why? haha.. What is your need to know?
The most sensitive aspect of IP is the PCT process for international
coverage since the US recognizes IP at the time of creation, and every
other nation on Earth recognizes at the time of patent.
So discussing technical details beyond what is actually issued - can
be a problem with US coverage that you want to take worldwide.
Just a point of order.
One wonders why you could use uspto.gov search engine? If I've
cleverly concealed by identity by this asterly subtrefuge of calling
myself willie mookie, I don't know if I want to give you enough
information to penetrate it! haha.. Great minds that you are. lol.
Here is one published patent - which I've referred to elsewhere as
well
United States Patent 7,081,584
Mook July 25, 2006
Solar based electrical energy generation with spectral cooling
Abstract
Method and system for converting solar energy into electrical energy
utilizing serially coupled multijunction-type photovoltaic cells in
conjunction with a form of spectral cooling. The latter cooling is
carried out by removing ineffective solar energy components from
impinging concentrated light, inter alia, through the utilization of
dichroics or the conversion of ineffective solar energy components to
effective energy components by means of luminescence, phosphorescence,
or fluorescence. Ineffective solar energy components are described as
those exhibiting wavelengths outside the bandgap energy defined
wavelength and an associated wavelength defined band of useful photon
energy.
And there is two published applications
United States Patent Application 20060185713
Kind Code A1
Mook; William J. JR. August 24, 2006
Solar panels with liquid superconcentrators exhibiting wide fields of
view
Abstract
Solar panel system and apparatus wherein the panels are configured
with liquid superconcentrators having outwardly disposed liquid
imaging lenses of wide field of view performing with a sparse array of
discrete multifunction photovoltaic cells which are electrically
interconnected to provide a panel output. The liquid superconsentrator
and associated sparse array of photovoltaic cells are configured in a
row and column matrix and are mounted upon a polymeric back support.
United States Patent Application 20050051205
Kind Code A1
Mook, William H. JR. March 10, 2005
Abstract
energy.
There is considerably more on the way, and work is also patented, and
in the process of patent, that I've funded from outside vendors that
have resulted in patents and have had licensed to me - this approach
was taken so that the path isn't too easily followed by others, or
thwarted by those whom I have attracted negative attention.
But clearly there is enough out there to show that I'm serious about
this, and that I've built hardware and I'm in the process of putting
together major manufacturing. When we start shipping panels to
Indonesia to create the world's largest solar panel array - covering
360 sq km - from the world's largest panel production plant - making 1
sq km a day - a plant that every week makes more solar panels than
exist in the entire world today - then the US press may break down and
give us thekind of pointers you are looking for. haha..
