Piccolo Pete
- Jan 1, 1970
- 0
I was given 4 batteries. They are velcroed together (two each) to form what
I suspect to be a 12 volt configuration so that the two cells together are
about the size of a small car battery. I believe them to be 6 volt lead
acid batteries only because they have a Pb recycle label on them. The only
other marking I can find on them is the number "971226B", but a google
doesn't help with that number. They are black cased, 6.5"x7"x3" with sturdy
lead terminals.
I've had them sitting in my garage for about 2 years and forgot about them
until just recently when I decided to start doing some solar/wind projects.
I measured the output at about 5 volts so that is why I came to the
conclusion that they were 6 volt units. They seem to hold a charge at about
7 volts from a trickle. I didn't want to, but I accidently left one
charging over night at that level...
I have 2 solar cells rated at 5 watts each - putting out about 13.5vdc at
..450 amps max.
I also have 2 old (but mint condition - because I never used them) TC25G
generators. I made a small turbine for one, but haven't done the gear box
yet.
My questions are:
1. Got any clue of where I can find specs on these batteries?
2. Do you think they would be good for a small solar/wind system?
3. In a 12 volt solar configuration (2 batteries in series - to form one 12
volt battery - giving me a total of two 12 volt batteries), what would be
the recommended solar configuration?:
a. should I put both 12 volt batteries in parallel with both solar
cells in parallel (with a diode on each solar cell, of course)?
b. should I charge each 12 volt battery separately from one solar cell
each?
4. Do I need a charge controller on such a small system?
5. Do you have a link to any good sites with DIY charge controllers (I can
read schematics and do electronics fairly well)?
lead terminals.
..450 amps max.
yet.
My questions are:
each?
