Unknown PSU switch.
roughshawd
Jul 13, 2020
616
Time for a comedy break! This is all rhetorical non sense so bear with me....
The pics are of a standard design factor for some kind of normal thing folks want. Ok. It has 3 relays 2 5 ohm joules/10watt ohm resistors, a fuse, a transformer a couple of dip chips and 3 ports for what ever it powers and switches. One of the chip is tape labels with SG0008J. And it's also got a beeper on it and the complete setup is switched, through the fuse. I have attached a standard two prong plug to board, which has a switch built into the line The ports are as follows.
PA1 PA2 PA3, 1 is 4 pin, 3 is 3 pin, and 2 is 6 pin.
The board is putting out a nominal 6.5 v and the relays are tv-5, SRU-5-112L 240v source and 24v signal at 10amps.
I want to build functional switches to trip the individual relays, and use it as a switched bench top PSU, how can someone find out the pin outs on the ports, so they can build the triggers?
Please note... I can't remember what this was in, or where I got it!
roughshawd
Jul 13, 2020
616
kellys_eye
Jun 25, 2010
6,512
That looks like a washing machine control board.
Remove the relays and wire directly to the coils, using the contacts how ever you want.
The power supply components are the transformer (top of the board) and the three items to its right, a bridge rectifier, smoothing capacitor and U1. Remove them from the board and wire them up accordingly.
