K
[email protected]
- Jan 1, 1970
- 0
Was given a previously working Mobo to replace my bad Compaq one. They
are the same form factor so it is a drop in.
Am posting this because the Mobo docs were lost. Am trying to
determine what the start connectors are because while the front panel
connector is printed on the board (2 rows of 12 pins with 3 missing
pins) there is no list of start and other functions.
The Mobo has an Award BIOS so was told that can use it to trace the Mfr
and other info. On the bottom ISA connector is a label with Award 1998
PCI/PNP586 146680663 and another label with S/N:M990113475. The upper
left area has FI (in a squashed circle) 4-V-0 and 0299 (in rectangle).
Used Wimsbios http://www.wimsbios.com/numbers.shtml but my Award
numbers do not match the format.
The Catch 22 is that the correct Award numbers come from the BIOS
screen "The AMI or Award BIOS id appears at the bottom of your screen
after power on, during memory count up. The PAUSE key should work at
that point, allowing you to write down the BIOS number, the BIOS date,
and the version. You must copy it exactly." which I am unable until
determine the start connectors.
Would be Very Interested in any suggestions.
Ken
Ken
