Usb trigger for 12v TV backlight
carpenter940
Mar 27, 2013
4
I have a strip of 12 volt LED lights that I'd like to use for a TV backlight. I'd like the LEDs to come on/off when the TV is powered on/off. I'm using the USB on my TV as my trigger.
Will someone take a look at it to see if it's OK to use on TV w/o destroying TV?
The parts I will use are:
USB cable connected to 5v USB out on TV
R153S Diode (the R153S was the only indicator of it's value)
1/4W 0.25W 5% 220 R OHM Carbon Film Resistor
IRF520 Power MOSFET N-Channel TO-220 GM
Led Strip 3528 SMD White lamp DC 12V
12v source for LEDs
Below you will find a link to the schematic.
http://tinyurl.com/y84rxw35
Thanks for any help.
NOTE: I'm not very good at electrical circuits.
Externet
Aug 24, 2009
944
I do not see anything wrong with it.
You could choose a relay if makes you sleep better.
IRF520 requires 10V to turn on fully. It might work at 5V, but typically cannot pass more than 2A at that gate voltage, and will be dropping between 1 and 2V at that current. You need a logic level MOSFET like the IRLZ44.
carpenter940
Mar 27, 2013
4
Thank for the replies. Now that I went back and looked at the data sheet for the IRF520 I see it DOES require 10V, but you wrote it may work at 5v too. I decided to take a chance since I already had a IRF520 and constructed the project and it seems to be working fine plugged into a 5v phone charger. I'll leave it plugged in for awhile to make sure it doesn't melt before plugging it into my TV.
14,317
If it works, it may not be reliable. It may be seemingly on, but have a comparatively high drain-source resistance which will heat it up, shortening its lifetime considerably. I really recommend you follow Bob's advice.
I would expect the MOSFET to get quite warm if not hot with 5V on the gate. How much current is the strip using?
carpenter940
Mar 27, 2013
4
The strip had 75 LEDs on it so about 1.5 amps. Actually I plugged it into a phone charger as a test for over 2 hours and the MOSFET was still room temperature, didn't feel warm at all, kind of a surprise.
