VU meter
mik3ca
Aug 13, 2006
63
I'm trying to make my own VU meter, and I only have partial success. What I would like is full LED from full volume. My LED doesn't dance to the music :(
The input is a resistor (which varies the strength) and a capacitor in series. This capacitor is connected to any audio source directly.
this circuit uses a 2N4403 PNP and a 2N2222 NPN. The last NPN is used to give the LED a boost.
I think I am OK with choosing resistor values, but the capacitor values are trouble. If I choose them too high, then I will have to wait while they charge.
How do I choose the correct capacitor values?
I am interested in converting normal audible sounds into LED signals.
audioguru2
Apr 6, 2004
12,026
Hi Mik3ca,
Your circuit doesn't have a current-limiting resistor between the transistors. So when the PNP has a high input level then its collector current is unlimited and one or both transistors will blow up if the battery can supply enough current.
I don't know why you have a filter capacitor. Usually a capacitor is used with a rectifier circuit to hold the highest level for a moment so you can clearly see it.
You are trying to make 1/10th of an LM3915 or LM3916 bargraph driver IC. Why not use one, with the Half-Wave Peak Detector circuit shown in their datasheet? One pin selects between many LEDs lighting as a bar, or just one lighting as a moving dot.
mik3ca
Aug 13, 2006
63
audioguru said:
Hi Mik3ca,
I haven't had a transistor blow up in this configuration.
Talkingelectronics.com uses a diode in place of my capacitor. I tried that configuration without much success. When the diode is connected this way, doesn't it create a varactor? Which means there is guaranteed capacitance.
then I must be on the right track.
Why not use one
Because I don't want IC constraints to affect my design.
with the Half-Wave Peak Detector circuit...
I am going to search for that. Thank you.
audioguru2
Apr 6, 2004
12,026
In the VU meter project at Talking Electronics, the PNP transistor, diode, input capacitor and collector capacitor make a Half-Wave Peak Detector (rectifier circuit) with a fast rise time and a longer release time of its storage capacitor. Then each LED lights long enough that you can see its level clearly. Without the diode and storage capacitor the LEDs would be a dim blur.
The 47k resistors between the PNP transistor and the NPN transistors limit the current like I was saying so that the transistors don't blow up and that the battery isn't killed from excessive wasted current. The 47k resistors also allow the storage capacitor to discharge slowly.
The diode is a rectifier, not a varactor.
mik3ca
Aug 13, 2006
63
that was the circuit I was talking about.
That circuit barely works for me IF the resistor value is low enough.
Sometimes, when I use the diode, the LED just stays on bright, and never dims.
So the RC circuit in parallel determine the holding time?
What if I were to replace the diode with one that can handle more power like the 1N4007?
audioguru2
Apr 6, 2004
12,026
Which resistor, its input level pot? It needs a pretty high signal level, 0.65V peak which is 460mV RMS. You should amplify its input with a preamp like they show.
The circuit is missing a resistor across the PNP's base-emitter to turn it off. Try 100k.
Maybe your input wires are not shielded and are picking up mains hum.
Yes, about 22ms. A very quick blink.
Power?  It is only micro-watts.
A 1N4148 has a clear case and light makes it behave like a photocell a little. Some 1N400x's have a black case and light won't affect it. Try it.
mik3ca
Aug 13, 2006
63
I tried adding resistors, and making it more like talkingelectronics version, but that didn't help.
At the moment, my input wires are about 6 inches long, because this section is in the beta stage, and my radio portion works.
I want to minimize holding time, in case I pick up sudden changes in the signal. In fact, I would like to pick up some white noise too!
Why would I need a photocell to detect a signal?
Is there a way to avoid the need of a photocell? (or a diode that behaves like a photocell?)
audioguru2
Apr 6, 2004
12,026
You said the LED stayed on. The PNP transistor is missing a resistor to turn it off.
6 inches of wire is a good antenna for interference pickup. The input wire must be a shielded audio cable.
22ms is a short blink. Try reducing the value of the capacitor for a shorter hold time then the LED won't be bright enough for you to see short duration signals.
Maybe your problem is caused by the clear 1N4148 being affected by light. Try a black diode to eliminate the light problem.
