N
N_Cook
- Jan 1, 1970
- 0
Believed to have been making an "electrical smoke" smell but performed
faultlessly for a gig, just general smokey smell , nothing specific to this
amp, I am trying again to find out why this amp is supposed suspect and not
anything else.
During the gig the stage supply tripped out. Nothing found amiss and powered
up lights and amps and continued .
No discolourations / open Rs/ open user or 7 internal fuses etc. Removed the
Zobell R and it is .8R rather than 1.5 ohm , but I don't think is
discoloured enough to have been burning.
No disc ceramics etc between ground and live / neutral.
Filter block X2 type 375V ac across L-N marked .1uF R .46 measured .024uF on
C and 1.2K on R scale on 1KHz RLC meter. Now hacked into and no sign of
smoke or overheating inside the cladding. It lays next to the dropper for
the mains relay and slightly discoloured cladding ,one-sided externally,
from that proximity probably.
Currently exploring the power amp which looks fine but in case one or more
transistors has gone open circuit and brief enough short circuit to trip the
mains trip but not any fuses .
No trace of smoke around the large mains Tx but will unbolt to check
underneath.
Any other suspects that would leve no trace?
How to find a problem , if there is not one to find?
anything else.
underneath.
