Jan Panteltje
- Jan 1, 1970
- 0
You talk nonsense.Um, no they don't what? Generate x-rays? Well, I'd have to disagree with
you on that, Andrew. Jan is right. They can -- if the voltage gets high
enough, which it is kept from doing by a circuit that monitors it and shunts
it to ground if it gets too high. It doesn't generally shut the tv down...
just prevents that voltage from going high enough to cause x-rays. If you
shoot a high energy electron beam (you give it higher energy by increasing
the potential) at a metal target, the metal target will emit x-rays. Basic
x-ray theory. (I was an x-ray machine repairman for the army for a while)
It just takes a higher voltage than is used in an average tv. When you were
a kid, didn't your mother tell you not to sit too close to your tv? That's
because she had heard that a television will emit low end x-rays. Because
back then they didn't build prevention into them. Incidentally, the lower
the energy level of an x-ray the more likely it will be to injure the body.
There were kids who ended up with cancer in their feet at that time, because
they would lay with their feet next to the set and watch hours of tv.
If you can't detect any x-rays now, that's because the circuitry to prevent
them is working properly. Also, you may have been measuring at the front of
the picture tube... but those are made of leaded glass (to stop the x-rays)
so they don't emit much in that direction. The glass of the bell and neck,
however, is not leaded, and also is much thinner. Even with the old sets,
the x-rays were emmited mostly out the back of the set. Now you will often
see a metal shell surrounding the bell of a larger set. That is because the
larger picture tube requires a higher voltage in order to accelerate the
beam properly, and they can emit. So they add the shield to catch any stray
x-rays.
You shouldn't accuse people of not knowing something that you don't know.
It can backfire on you.
Almost of not all TV are 25kV
ALL TV sets have stabilized HV, so 'the ciruit' is the stabilizer.
I have had tests in the studio for the monitors, where xrays were actually
measured, and the level was as close to zero not to worry about it (for kids
too).
The metal around the tube has nothing to do with higher voltages, just
screening (degausing coils are in there).
OP mentions there was an xray detector, that is bull, there is not.
If your mama told you not to sit in front of the TV it was likely because
of the adult content.
As I mentioned in an other post in the old sets there was a PD100 parallel
stabilizer that actually DID emit a bit of xrays (it colored the tubes glass),
it was in a metal case with a safety switch.
Many technicians had it open with the switched bridged to check for things
like arcing etc...
So, how many TV (not roentgen sets) did you servie, and how many did you design?
So we know you DO NOT know what you are talking about.
JP
