what or how to check CRT HV anode wire repair ?
robb
I changed the CRT HV anode wire on TEK o'scope by ...
- removing the silicon glued cover/cap
- desolder old anode lead
- clean silicon
- solder new anode lead
- re-silicon the lead cover/cap
Now ? is there any test i should perform to make sure i did the
job correctly/well ?
Like checking for corona leaks or any other such matters ?
Best method to do these tests :)
Also i noticed the Aquadag coating on the good CRT is alot more
uneven (bumpy) is there anything that should be done with the
Aquadag ?
Any useful ideas and help appreciated.
robb
James Sweet
- clean silicon
Aquadag ?
robb
Turn it on in a dark room and look for corona, smell for ozone, listen for
sizzling, and pull the plug if anything bursts into flames :)
Sjouke Burry
Ahhh!!! why deny us the pleasure of a nice bonfire?????
(have a video capable phone ready please!)
Jim Yanik
- clean silicon
Aquadag ?
robb
I'd allow a sufficient time for the silicone to cure FULLY.
Otherwise,it becomes a leakage path.
Better to wait too long than too little.
robb
Jim Yanik
Hello Jim,
Thanks for help.
I created a mock up cap and silicon seal on a piece of glass
just after the repair cap and seal so that i could check in 24
hours to see where the mock up was in the curring cycle.
I was planning to wait 24 hours, check the mock up curring and
then see if i should wait another 24.
Thanks for the help ,
robb
robb
Haha....
I may eat my soldering iron if it bursts into flames. (after it
cools down... the soldering iron that is)
thanks, i think,
robb
robb
Ok, so i will start he video camera before i turn it on
the next uTube hit :{
robb
robb
Arfa Daily
- clean silicon
Aquadag ?
robb
An AM radio nearby can give a good indication of corona discharge. You get a
sort of a 'whining' noise. Breathing on the area with a good "HAAAAA" will
also show up any tendency for corona, which takes place more readily when
the air surrounding any potential discharge site, is made moist. With the AM
radio on, wave a screwdriver around the area. Again, this will provoke any
potential sites, and you should hear it. Eveness of the outer 'dag coating
should not be of any consequence.
Arfa
robb
moist.
Hello Arfa,
Thanks for reply.
Breathing with a HAAAAA ? is this going to be one of those the
HAAHAHA, the jokes on me kinda of suggestions ? where my ears
buzz, i see flashes of light and my eyebrow twitches for the rest
of the day. :)
Sounds suspiciously like one of those suggestions the Senior
engineers give to the new rookies to amuse themselves and the
other senior engineers.
With the AM
Arfa
as long as it does not provoke a zap on me then i will give it a
try.
Thanks for the help Arfa,
robb
Arfa Daily
robb said:
moist.
Hello Arfa,
Thanks for reply.
of the day. :)
No, it's quite genuine. You need to "HAAAA" like a giant sigh, rather than
blow like putting out a candle. This shifts a large volume of slow-moving
and moist air into the area. Any spikes on the soldering or poor insulation
on the HV, will discharge much more readily into moist air, than dry air. It
represents no danger to you, as nothing is going to jump that distance,
unless your 'scope tube has a PDA with about a 100kV on it ...
try.
The metal shaft of a screwdriver with a plastic handle, held in your hand,
will draw a good arc from a high voltage supply, without you feeling a
thing. In the good old days of valve (tube) only TV sets, it was a standard
test to pull an arc from the top caps of the boost rectifier and HOP valves.
Also, from the cap of a DY87 or the wires of an EY86 HV rectifier valve. You
couldn't do it in later sets, because of those new-fangled transistor
things, that would just expire if did anything like that within about 2
yards of them ! Anyway, the point is that if there is anywhere that has a
predisposition to corona discharge, a metal screwdriver blade waved in the
vicinity, will likely help it along. I'm not talking a big long spark
jumping out at you, just some ozone, or maybe a discharge that you can hear.
Trust me ! No dangerous suggestions from this quarter, ever ...
robb
Arfa
jakdedert
Related: Check your car's high tension (spark plug) wires. On a dark
night, away from ambient light; open the hood with engine running.
Leaky HT wires will be readily apparent.
I had an AH Sprite that 'accidentally' introduced me to this technique,
which I've seen published since. I opened the hood for some
reason...blue sparks were dancing all over the engine. I replaced all
the HT leads toute suite....
jak
Baron
hand, will draw a good arc from a high voltage supply, without you
feeling a thing. In the good old days of valve (tube) only TV sets, it
was a standard test to pull an arc from the top caps of the boost
rectifier and HOP valves. Also, from the cap of a DY87 or the wires of
Arfa
This reminds me of an incident many years ago in a TV repair shop.
Several of the engineers had been feeding a mouse and it had become
quite tame, running down the back of the benchtop. Anyway one day
someone managed to zap it with a loose anode cap lead. I'de never seen
a mouse glow blue before.
robb
Silicon cured, CRT installed and tested.
Sorry no fireworks or shooting flames :D
thanks to Arfa, Jim, James, Sjouke etc...for the help.
Installed the new CRT and watched for all the symptoms and signs
people mentioned in the (sci.electronic.$$$$$) groups
No HV problems. But now the scope needs display adjusting to
suit the new CRT.
Problems:
The display is skewed and the intensity and focus are off.
I was not expecting te new CRT to have hyper-intensity troubles.
That is... from no visible trace to oversaturated CRT brightness
is a very small range of knob motion maybe a 1/4-1/3 of he full
turn .
And the focus is very sensitive, touch sensitive ? was not
before.
And the internal probe calibration signal (.5 V @ 1 kHz) produces
a trace with fuzzy band for peaks ( 20 - 30 mV) or so wide. This
was not the case before maybe more like (5 mV ripple before CRT
swap)
So hopefully i can sort these problems out.
thanks for all the safety advice,
robb
Jim Yanik
suit the new CRT.
It needs a complete calibration,not just a "display" adjust.
Adjusting vertical and horizontal gains affects freq.response.
Problems:
trace rotation,geometry and astigmatism adjusts.
turn .
That doesn't sound very good. That CRT may NOT be a usable replacement.
What model scope,and what CRT part numbers,old and new?
Arfa Daily
suit the new CRT.
Problems:
turn .
before.
swap)
It sounds to me like this replacement CRT might not be quite as 'compatible'
as you had hoped ... :-( Maybe that's part of the reason that the PDA lead
was not long enough to fit in your chassis i.e. to stop such a substitution
taking place. As far as the trace being 'skewed' do you mean that it is not
perfectly horizontal, or that it is trapezoidally distorted ? If the former,
then most decent 'scopes have a trace rotation control somewhere. As far as
the brightness / focus issues go, that is likely to be quite difficult to
resolve, and will probably require changes to be made to the component
values in the resistor chains providing the biasing voltages to the various
electrodes. I would suggest that you will not get too far with that, without
having schematics for both the 'scope that you've put the tube in, and the
one that it came out of, so that you can make comparisons of values and
expected voltages. Just as a matter of interest, are the quoted deflection
sensitivities for both tubes the same ?
Good luck with it - I think you'ree going to need it, but it's nice to see
that a sense of experimentation still exists out there - it's the sort of
thing that I would have been playing with 30 years ago ...
Arfa
robb
Hello Arfa,
It is a Tek scope.
There are lots of pots for adjusting the CRT params.
The CRT was replaced with its **reverse** compatible replacement
P/N.
That is, typically one replaces the earlier model CRT with the
newer model and i have done the reverse. I replaced the newer
model with the earlier model. Unless it was a "one way
compatibility" then technically it should work.
The HV lead was longer in newer models because of physical change
to the Flyback/HV multiplier transformer and orientation. The
earlier model machines had an HV Jack on an 3" HV lead coming off
the Flyback the newer models have te HV Jack on the Flyback
directly.
So you need just 1" (2.5 cm) more HV lead to make it there.
Hopefully i can cure problems with the adjustments, as I do not
really want to modify the original PCB /schematic values.
Thanks for help and ideas Arfa,
robb
Arfa Daily
robb said:
Hello Arfa,
It is a Tek scope.
P/N.
directly.
robb
Hmmmm. Sometimes, compatible substitution *is* a one-way street. If the
parameters of the two tubes were sufficiently similar, I would not have
expected there to be a huge difference in the external setups, or for the
operation of the user controls to become 'bunched' as you described. There
are a couple of Tek 'scope experts who pop up on here from time to time who
would be much better qualified to advise you on the specifics of your
problems than I, so hopefully one of them will dive in to help you shortly !
Arfa
Jim Yanik
the parameters of the two tubes were sufficiently similar, I would not
have expected there to be a huge difference in the external setups, or
for the operation of the user controls to become 'bunched' as you
described. There are a couple of Tek 'scope experts who pop up on here
from time to time who would be much better qualified to advise you on
the specifics of your problems than I, so hopefully one of them will
Arfa
it would help if he said WHAT MODEL Tek scope,and maybe the part numbers of
both CRTs.
robb
both CRTs.
Hi Jim,
apologies , i thought i had already mentioned model and P/N.
I know you are just trying to help and i am making it difficult.
The scope is a Tek 2232.
The bad CRT with P/N: 154-0861-10.
The replacement CRT has P/N 154-0861-00 .
I still in process of completing the suggestions/advice you made
earlier with astig/geom/gain etc.
i planned to revise the operation ststus when completed.
thanks for your help Jim,
robb
Jim Yanik
Hi Jim,
robb
IMO,the 861-00 should work in place of the -10.
Of course,you may have a problem with the new -10 tube.
Don't overlook the CRT socket itself;a bad connection on one pin could
cause what you are seeing.Even a pin-corrosion problem on the CRT pins
could be the problem;TEK used to make an abrasive-rubber CRT pin
cleaner,it's material similar to a Kratex polishing burr.
The pin cleaner had a hole in the end and you slid it over the CRT pin and
rotated it to clean the CRT pin.
(no,I don't have a p/n for it)
I've also seen loose CRT socket connectors,and replaced CRT sockets for
similar problems.
