John Larkin wrote...
Dang, I was going to say that, but I was too busy eating.
I've done lower voltage situations with a bipolar/op-amp under
the cathode of a toob.
Yes, of course, that's the way to do the tube solution. I realized
that just after hitting SEND. I've often seen this done before, but
my memory was slow to reveal the answer.
However, the tube approach is still rather complicated, because the
"grounded grid" tube with its programmable current-sinking MOSFET
cathode driver (500V, 1A - not too bad) and its 50W filament power,
will all be sitting at -16kV. Hmm, that better all be inside a big
Faraday cage with rounded corners. Can't have corona discharge off
of our sharp-edged components! Maybe we can use a clear housing, or
add some windows.
A 5D21 or 4PR60C tube needs to have 50W of filament heating removed
(Eimac says by radiation and forced air, but there's no air chimney).
Damm, I hate to think of all the dust that'll collect on the -16kV
surfaces; maybe we can seal it, and use recirculating air with some
type of heat-exchanger. We can monitor the temperature. Hmm.
We'll need a two-way optical-fiber communication link (for DAC and
logic signals up, ADC diagnostic info back).
We'll need to make or buy a 75W, 20kV-insulation-rated power source
for the cage, mostly for the filament. We can use a dc-dc converter
inside the cage to get say 600V to 800V for the screen grid (the
cathode will be 100 to 350V above the "grounded" grid). Hmm.
We might need a pullup resistor or current source for the cathode,
up to the 600V supply, to allow for rapidly turning off the tube by
charging the MOSFET's drain. Hmm, ahem. No, that probably won't
be necessary, the tube's high current when running should do that
fast enough, the cathode capacitance will be under 100pF. Hmm.
That's only 200V/us at 20mA, maybe we'd better use one after all.
The operating range of the pulser will be about 0.1mA to 1A.
Well, it's still less of a mess than the cascoded-MOSFET solutions
I've sketched out so far... Hmm.
