Yonanas ice cream maker won't turn on
mikey5791
Jun 7, 2013
174
Hi all,
This Yonanas brand ice cream maker was given to me at no working condition. The previous owner said it was working fine before. So i did try switch on power but it shows no life, motor not turning. So i opened it up, desoldered the 4pcs black diode marked 5408. Tested using an analog multimeter, one side anode no continuity while other side cathode has continuity. Diodes 4 pcs tested ok. The fuse at RV1 has continuity.
I ran out of idea where else to check since the power board looks clean and no burning mark whatsoever. Please kindly help to diagnose. Thank you.
14,484
I would be checking the power switch, as seen in your 3rd photo, make sure it is operating
mikey5791
Jun 7, 2013
174
Hi davenn,
I had checked the switch by probing multimeter on both side switch connector.when switch is off, the multimeter show no continuity.
Btw, how do i check if the motor is working and not shorted. Any idea please. Thank you for reply.
14,484
OK :)
you hadn't commented on the switch, so I thought I better ;)
So, your response assumes you had continuity when the switch was in the on position :)
can you freely spin the motor?
does that power board feed any other electronics that I cant see from your photos ( speed controller etc) ?
mikey5791
Jun 7, 2013
174
Yes, when the switch is on, the multimeter show continuity.
I try manual spin the motor and it is a bit tight, but still able to spin slowly.
I checked the wires, somehow it does connect to some sort of carbon brush switch but not sure what it is as on picture.
The machine does not have speed controller though. Please kindly advise.
Can you measure the resistance across the motor and let us know what it is?
kellys_eye
Jun 25, 2010
6,512
I wouldn't take a continuity reading from that switch as definitive proof it's working (properly). I recognise the the switch 'type' and they are quite notorious for intermittency and failure under load.
Use a crocodile clip (insulated) to physically short the switch contacts and try powering up again.
If it still doesn't work then uncover the components that are covered in heatshrink material and in line with the motor supply leads. They may be in-line chokes, small resistors or even fuses......
mikey5791
Jun 7, 2013
174
Hi Steve,
Using a digital multimeter(dmm) the resistance across the motor reads 69.6 ohm. Does this reading seems normal?
mikey5791
Jun 7, 2013
174
Hi all,
After running out of idea, i noticed i missed out on that piece of black brush like switch. This switch is like a spring type operated mechanically by locking a black plastic cup with notch to switch on.
I tried locking the black plastic cup to the blender body and voila the motor spins after i switch on power. Haha, actually the machine works without fault in the first place. Thanks all for help.
skilliknow
Aug 12, 2022
Hi all,
This Yonanas brand ice cream maker was given to me at no working condition. The previous owner said it was working fine before. So i did try switch on power but it shows no life, motor not turning. So i opened it up, desoldered the 4pcs black diode marked 5408. Tested using an analog multimeter,ice cream maker this blog one side anode no continuity while other side cathode has continuity. Diodes 4 pcs tested ok. The fuse at RV1 has continuity.
Can I freeze Yonanas after I make it?
