Sound Level Indicator
- Audioguru
- 38.553 Views
- medium
- Tested
This project uses an LM3915 bar-graph IC driving two sets of ten LEDs for a 30dB range. The circuit is unique because it has an additional range of 20dB provided by an automatic gain control to allow it to be very sensitive to low sound levels but it increases its range 20dB for loud sounds.
The LEDs are operating at 26mA each with the brightness control at maximum, which is very bright. The circuit has a switch to select the modes of operation: a moving dot of light, or a bar with a changing length.
My prototype has a little 9V Ni-Cad rechargeable battery in it to be portable and the battery is trickle-charged when the project is powered by a 9V AC-DC adapter.
Schematic
Circuit Description
1) The electret microphone is powered by and has a load of R1 from an LM2931 5V low-dropout regulator.
2) The 1st opamp stage is an audio preamp with a gain of 101.
3) The 2nd opamp stage is a single-supply opamp which works fine with its inputs and output at ground and is used as a rectifier driver with a gain of 1.8. It is biased at ground. Since it is inverting, when its input swings negative, its output swings positive.
4) Three 2N3904 transistors are used as emitter-followers:
a) Q1 is inside the negative feedback loop of the 2nd opamp as a voltage reference for the other two transistors. Hopefully the transistors match each other.
b) Q2 emitter-follower transistor quickly charges C8 which discharges slower into R13 and is used as a peak detector.
c) Q3 transistor is the automatic gain control. It is also a peak detector but has slower charge and discharge times. It drives the comparators resistor ladder in the LM3915 to determine how sensitive it is. R15 from +5V is in a voltage divider with the ladders total resistance of about 25k and provides the top of the ladder with about +0.51V when there is a very low sound level detected. Loud sounds cause Q3 to drive the top of the ladder to 5.1V for reduced sensitivity.
5) The LM3915 regulates the current for the LEDs so they dont need current-limiting resistors. In the bar mode with all LEDs lit then the LM3915 gets hot so the 10 ohm/1W resistor R16 shares the heat.
Options
1) You could use a switch to change the brightness instead of a pot, or leave it bright.
2) You could use an LM358 dual opamp (I tried it) but its output drops above 4Khz. The MC33172 is flat to 20kHz with this high gain.
3) You could add a 1uF to 2.2uF capacitor across R5 so the indicator responds only to bass or the beat of music. Then an LM358 dual opamp is fine.
Construction
1) The stripboard layout was designed for a Hammond 1591B plastic box with space in the lower end for a rechargeable 9V battery. One bolt holds the circuit board and a second bolt was cut short as a guide.
2) A second piece of stripboard was used on a diagonal to space the LEDs closely together. A few LEDs needed their rim to be filed slightly to fit.
3) A third piece of stripboard was used as a separating wall for the battery and it interlocks with the LEDs stripboard to hold it in place.
4) 11-wire flexible ribbon cable connects to the LEDs.
5) Use shielded audio from the microphone and a rubber grommet holding it.
Parts List
R1–10k
R2, R3, R5, R7, R8, R10–100k
R4–47k
R6–1k
R9–56k
R11–4.7k
R12, R14–100
R13–330k
R15–220k
R16–10/1W
R17, R19–390
R18–22k
P1–10k audio-taper (log) pot
C1, C4, C8–330nF
C2–47uF/10V
C3, C9–100uF/10V
C5–100nF
C6–470uF/16V
C7–10uF/16V
IC1–MC33172P
IC2–LM3915P
5V reg–LM2931AZ5.0
LEDs–MV8191 super-red diffused
Electret microphone–two-wire type Box–Hammond 1591B
Battery–9V Ni-Cad or Ni-MH
SW1–SPST switch
Adapter jack–switched
Do you have a video of it reacting to sound?
We are sorry, no video available at the moment.
what alternative can I use for IC1–MC33172P because I cannt find it.
Found it here: https://www.futurlec.com/ICSFMotorola.shtml you may also check on ebay
Can we increase the range up to 120 db ?
Could you please give your calculations?
