23 -
About CooperMan
- Birthday 05/02/1951
CooperMan's Achievements
Hi all, As Ante says, this is great news. Few! He had us all a little worried for a while but again great news he is ok. I hope, with the software I sent him, he will be back on line soonest. Bob...
can you please give him my regards and let him know I have sent him the CDs I said I would for helping me out with my washing machine pump problems. (60Hz power with 50Hz pumps ???) I sent him: Ghost, Windows 2K Professional, Office XP, and Photoshop V7.01. CooperMan
Ignition coil driver circuits and experiments
CooperMan replied to steven's topic in High Voltage Stuff
Following on: "Any electronic device operating at a potential above 10,000 volts should be considered as a possible source of x-radiation even though it was not designed for that purpose. Devices are not considered hazardous when operated at voltages below 10,000 volts because the inherent shielding, such as is provided by the device walls, is generally sufficient for adequate attenuation of the x-rays. Even at somewhat higher voltages, this inherent shielding may be sufficient to reduce the radiation to an acceptable level." Go see: http://www.abwem.wpafb.af.mil/radiation/index.cfm?id=66&objid=126&cat=Radiation%20Safety -
Hi,SM2GXN, I'm getting quite concerned about him as he said he was ill when we got talking one time. His real name is Stig Andersson but I think the Stig part is short for something or other. I have his address if you want it, let me know and I'll send it via your email address. I would look him up myself but I live in the Philippines. Regards, Bob...
Hi all you high voltage folks, I don -
Hi Everyone, Does anyone know what has happend to Staigen? I was talking to him on MSN but he has not signed in in the last two months or so. Now I'm getting a bounce from his email address. I hope he is okay. Regards, Bob..
Water Tank Water Level Indicator
CooperMan replied to CooperMan's topic in Electronic Projects Design/Ideas
Hi MP, This is just what I was looking for, thanks a million. Just one (or two) question for now as I set about making it: Q: Do you think that they have got the resistors, R1 through R5 in the wrong order? It looks like R5 should take the place of R2 and R2 through R4 should all move down one. Q: What values would you recommend, for the sensor resistors, if use 10 sensors instead of the five as in this schematic as my tank is 5 metres deep? Best regards and thanks again, Bob… -
Need to fix my Viewsonic P775 monitor
CooperMan replied to CooperMan's topic in Datasheet/Parts requests
Where is Bicol and what's a PM?? Bob -
Hi MP, I guess I didn -
Hi, logan_dslasher, This looks just what I -
Hi folks, I have been hunting around and have found the LM3915 dot/bar display driver chip. It looks like it should be ideal for my water level detector. I have a plastic ¾ inch water pipe that I can cut into sections and intersperse stainless steel sections with a stainless steel sealed of end being the bottom of the tank water level sensor. I see that I would need some type of resistive sensor set up between the SS sections; any ideas what this restive network might look like so I could feed the LM3915 chip to indicate the water levels. I really would sooner not re-invent the wheel if one of you good folks has already worked on something like this. I envisage some sort of resistive chain connected to the SS sections of the pipe, but can -
Has anybody got the service manual for a Viewsonic P775
Hi Ante, Yes it is a nice place to live apart from all the pore people here; the govenment are ****, well lets not go into that here. This is a big island off an even bigger island called Bohol and it's part of the Philippines. Map attached... What a good Idea; I'll look into it to see what I can find but thanks for the suggestion. Any Idea about an op-amp circuit if the ultrasonic ruler idea doesn't pan out? Regards, CooperMan Bob... -
One last snap, one can see the water in (from the roof) pipe, on the left, used to run-off the water from the roof so we can clean most of the crap. We then close this pipe and open the valve also on the bottom lift of the picture. CooperMan
