Ldanielrosa
316 -
Calendar
Everything posted by Ldanielrosa
I'm looking into casting small parts in brass and aluminum, but I don't feel like having a full blown foundry. I saw that with the right susceptor materials, crucibles can be heated by microwaves. Does anybody have any links to forums that are involved in this? I'll probably run with this no matter how little information I have, but I'd like to know the caveats.
Function Generator + LCD (Design Idea)
Ldanielrosa replied to AN920's topic in Electronic Projects Design/Ideas
That's a very good idea! I don't know if I should be surprised that is not standard equipment. Many years ago I paid too much by today's standards for a frequency counter, and I'm not always confident that it is working correctly. Considering how minimal the function would be for a microcontroller to do the job, I'll probably make six of them when the house is done and I can unpack my hobby stuff. As for the function generator, that may take longer for the need to drive me. -
I'm not sure how helpful I'll be, but it may help to turn off the caps-lock when posting here. Also, when was this assigned and how much longer do you have?
How to get better current from LM317?
Ldanielrosa replied to wuemura's topic in Electronic Projects Design/Ideas
I am curious about the 100uH inductor in the output leg of the regulator. Could this be contributing to the oscillation? -
Have you considered using double sided carpet tape?
Energy saving device - can they work?
Ldanielrosa replied to stacynewton's topic in Power Electronics
If you have the means to do so, I would certainly like to see a picture of the guts of this device. I don't know how they can claim to save any power with resistive loads like a range, toaster. or light bulb. Does anybody reckon they are designed to deceive the meter by using an amp or two at peak and feeding it back at higher current near crossover? If so it is illegal in several countries. -
This technique is best for that application. That and the other techniques are well suited for yon project. Sorry, I couldn't help it. Anyway, the gist is that to recommend a method we need to know more of what the implementation is.
I can't help it, I just have to get into it at this point. An Engineer is a qualification as shown on paper, but an engineer is a way of thinking. I am not the first (yet). From what I have seen, Audioguru has shown aspects of the second from time to time (like me). "Looks unusual"? Please qualify this, Audioguru. It will sound too close to prejudice to the uninformed masses (like me) if this statement stands alone. Yes I agree that datasheets are important, and compliance with them is wise. There is another thread that seems to advocate something that is not strictly in the datasheet of a certain device, which may have your influence. I do believe that some logical reasons were outlined, which has the earmark of an engineer. As for the article- I haven't looked at it directly. What I've read of it here does lead me to believe that- the author was having a bad day, or it was written early in his career, or there were tradeoffs that may have resembled a marketing influence (500W is absolute, one time only, run for your life maximum rating- don't ever count on it) like my 13,000,000W stereo (fictitious device). As for the article (still haven't read it), it may be wise to append that someone who may be qualified to speak on the subject (which I believe he is) is not comfortable with the specifications as given and recommends some alterations- but the original project is not yet known to fail.
I'm not all here right now, but it looked like you were asking about the "throttle" control on an engine carburetor. Reversing direction would be the transmission? If the "throttle" is actually for an electric motor, there is no guarantee that the servo standard applies- but assuming it does there are a great number of possibilities, which I dare not list for fear of making a fool of myself (which I may already have).
Noise handling algorithm in 8 wire touch screen
Ldanielrosa replied to hanhao's topic in Electronic Projects Design/Ideas
How often can you poll the screen for the touch coordinates? This sounds similar to several other things that I've pondered. I would consider getting enough data to establish a probable center for the "boundary circle", which you probably already did. Then keep sampling input data and averaging it with the previous position. You may be able to poll the position often enough that the jitter will be less than one pixel width. -
To attach an insect to a spring, you need an adhesive that will bond to both surfaces. Epoxy would be overkill since it will exceed the strength by orders of magnitude, and would take too long to cure as well. Cyanoacrylate would be fast enough, but I have heard that it will partially dissolve the insect's body. The best option is likely to be a double sided tape, like what is used for astro turf on patios. As for the circuit- what to you want it to do? Perhaps a microgenerator to harness the power of the insect? A microphone to record the insect's sounds?
White noise generator for mp3 players/ipod
Ldanielrosa replied to noiseannoys's topic in Electronic Projects Design/Ideas
I'm not sure I understand the full question. Do you want to generate a white noise audio file to listen to? If so there are two complications that I am aware of. First, MP3 compression works so well at saving resources by the use of "psychacoustics", which in less BS laden language means that it maps the loudest tones and their intensities. Upon playback, the tones are regenerated and mixed- the higher bitrate the more tones. White noise (or pink for that matter) contains a broader range of frequencies (theoretically infinite) than music, and their duration is very short so MP3 compression artifacts are no longer transparent. Second, the way computers usually generate random numbers may not be good enough for white noise. It may be good enough for dealing cards or rolling dice in a game, but our hearing is a bit more demanding. Any repetitive theme that happens at audible frequencies will be immediately noticed. The generation of pseudorandom bits with a slow repetition rate is not difficult. -
Thank you for your input, Kevin. This is what I hope to be true.
I guess I should have replied earlier, but here goes. If the gizmo doesn't need to do anything else when it's putting out the frequency of choice, then what I've been working on may be of some value. On a mothballed project that I will call a guitar tuner, I have some arithmetic subroutines that convert chosen frequency into a scaler value which is repetitively added to a 24 bit sum. The top eight bits are then used to fetch a value from a table, which is fed to an output port. An input pin is checked to determine if the halt button has been pressed, and failing that the cycle repeats at adding the scaler to the sum. At a clock speed of 4MHz I can get just over 10kHz output, but not by much. The DAC (R2R ladder) is external to the uC.
I've seen quite a few posts regarding SIM cards. Usually iterations of copying, reading, altering, whatever but they look like they're still meant to be used with 'phones. Did I miss something here? I'm looking at SIM cards as a removable media for embedded projects. Is this possible? I had assumed it would be, but I don't want to commit to tools and time to find them useless.
Antistatic foam that is used to store ESD sensitive chips is conductive, and will increase in conductivity when compressed.
Almost sorry to bump this to the top. The only response I've had was by PM. I'd really like to know if this is already done but with different names. Seeing as I think orthogonally to most people, my searches don't yield as many results as they should. Thanks for bearing with me.
I like to find someone to build prototypes
Ldanielrosa replied to dwangyahoo's topic in Power Electronics
When regulators fail, many alternators will produce voltages of which you speak at moderate engine speeds. You may be able to replace the regulator and change the pulley ratios to get the power source you seek. -
Please help on odd reference voltages
Ldanielrosa replied to aniruddha's topic in Electronic Projects Design/Ideas
With the resolution you seek, standard values won't get you there in one step. I recommend choosing one common value, and for the other leg combining resistors in parallel to trim the value down. For example: with a TL431 I would use a 10k 1% on the bottom leg which always sees a nominal 2V495, which I would measure with ref shorted to cathode. For the upper leg I would start with 750R and measure the actual resistance. After measuring the shunt voltage, expecting 2V655 to 2V709, I will know how far the '431 is off the nominal voltage and about how much reference current the chip needs. Then I would select a resistor to parallel with 750R to get the target value of 516R to 729R, which could be from 1k6 to 26k. -
Let me tell you about two of my favorite temperature sensors. The LM334 is a programmable current regulator. It is nominally a three pin device that is commonly available in TO-92 package. This varies current linearly with respect to temperature on the kelvin scale. The LM335 is a temperature sensitive voltage reference. It is also a three pin device in a TO-92 package. Usually only two pins are used, the third is available for trimming. The voltage is 10mV/kelvin. Both are available in TO-46 packages as well, which includes broader operating range and usually tighter tolerance.
The voltage requirements for USB is that at worst case (longest cables, highest drain, poorest connections) there must be a minimum of 4V3 _at the device_. If the device in question can stand to run on as little as 3V6, then a diode in series with the supply will cause problems. A diode in series with each supply is probably how the device in question prevents supply contentions.
If you are in no particular hurry, then I have a few TL431s and daughterboards I could spare. They need two 1206 SMD resistors each for biasing. They stand on edge and act like a two pin zener then finished. PM me if you're interested. -
It depends on the appliance type and sometimes on the appliance itself. Some things, like small power tools, blenders, and devices with a switching power supply (computers, televisions, VCRs) are not likely to complain about going from 50Hz to 60Hz, but some might. Things with AC motors like laundry, refrigerator, and air conditioning will change their behavior with different frequencies. If this causes a increase in the current then it may be destructive. Many clocks won't keep correct time. Good luck.
If it is the same frequency, then yes.
For the same reason iron filings stick to either pole of a magnet just as well. The core of an AC solenoid is not polarized. Fewer components make it cheaper to produce. Sometimes more reliable too. I will assume you are speaking of a DC magnetic field or permanent magnet. It will have a non-positive affect on the inductance and on the saturation current.
