hotwaterwizard
2,022 -
Everything posted by hotwaterwizard
Fast switching IC?
hotwaterwizard replied to New2Electronics's topic in Electronic Projects Design/Ideas
How about a Solid State Relay? -
Looking for data sheet for STi3520acv
hotwaterwizard replied to tigerwithelectroni's topic in Datasheet/Parts requests
Here you go! http://siou.free.fr/Documents/4674.pdf -
Need more Info!
Your English is not easy to understand.
Connecting An Audio Output to 20 Headphones...
hotwaterwizard replied to Shahriar's topic in Electronic Projects Design/Ideas
CHECK THIS OUT! http://www.paia.com/hda.htm http://www.paia.com/hdasch.gif NE5532 Datasheet Click Here NE5532 Application Note Click Here -
Demagnitize reception of radios
hotwaterwizard replied to quantum's topic in Electronic Projects Design/Ideas
My father use to use an RF signal Generator to Mess with me when I was playing my Radio too loud. He would block the signal and all I could get was a tone. -
Yes if the supply voltage is AC not DC. I have used 24 vac to get 220vac this way Also 120v input and I got 240v out. DC will not work unless you pulse it and send it thru.
I have a Tech Note. ST20-TP2X50_Tech_Note.pdf
Here is the first one! [attachment deleted by admin]
This is good for a crystal radio and other radio equipment but ib little gadgets it is not needed. Ac Equipment like Satalite Recievers Cable Boxes Telephone Systems Ect. Need to be Earth Grounded. Check out this Link http://www.ee.upenn.edu/rca/instruments/misctutorials/Ground/grd.html
How About This Circuit?
How about My Timer?
Cool Globe that Levitates http://www.davincisvault.com/index.asp?PageAction=VIEWPROD&ProdID=89&HS=1
They are also Known as MOVs Metal Oxide Varible Resistor oe Syrge suppressor Here is some Info on both. You can get an MOV at Radio Shack. http://www.meritekusa.com/productshow.php?ID=52&type=pdf http://www.inter-technical.com/index.php?page=products&manfilter=TKS&typefilter=&sterm=GetAllElements&rpage=3 http://www.inter-technical.com/datasheets/TVR_Varistor-Surge_Protection.pdf http://www.radioshack.com/product.asp?catalog%5Fname=CTLG&product%5Fid=276-568 http://support.radioshack.com/support_supplies/doc38/38010.htm
1SS82 = Manufacturer Part No. 1SS82 NTE Part No. NTE552 http://www.nteinc.com/specs/500to599/pdf/nte552.pdf ECG522=1S1834 1N4937 1SS82 = sk9000 1N4933 GI ECG552 SK9000 50PIV, 1a Fast Sw. Si Diode 1N4936 GI NTE552 SK9000 400PIV, 1a Fast Sw. Si Diode http://www.geocities.com/rxtxtubes/pa00036.htm EMX-300 103-131 113397 139706 1N4305 1N916 1S1555 1S1585 1S1588 1S2076 1S2473 1S276A 1SS133 1SS53 1SS54 1SS84 MA150 MA170 MA171 1N4548 1N456A 1N914 ECG177 1N4450 1N4148 http://matthieu.benoit.free.fr/cross/1n_.htm http://www.rangeraudio.com/stock1.htm
here is what I found so far. 1SS82 = EMX-300 http://www.rangeraudio.com/stock1.htm
Look here http://lcdhype.mod-extreme.info/lcdhypeforum/index.php?showtopic=266
Here is the first. [attachment deleted by admin]
pyroelectric sensor (PIR) data sheet
hotwaterwizard replied to zeplin inc's topic in Datasheet/Parts requests
http://kitsrus.com/pdf/k76.pdf http://www.cypressmicro.com/support/appnotes/an2105.pdf http://www.glolab.com/pirparts/infrared.html http://www.glolab.com/pirparts/pirparts.html http://www.electronics123.com/amazon/datasheet/kc7783.pdf -
http://zone.ni.com/devzone/conceptd.nsf/webmain/C83E9B93DE714DB08625686600704DB1?OpenDocument Click here for a bigger view
You can download most of them at www.datasheetcatalog.com 74SeriesTTL.pdf
Electronic weighing system
hotwaterwizard replied to darrins's topic in Electronic Projects Design/Ideas
Why not use a Timer to stop the Screw from turning after a certain time.. Use an adjustable Delayed off timer and just keep weighing the powder until you get the desired weight for the time you set. Then it will dispense the powder according to the limit you set. -
IC HELP: FOR Tx Design
hotwaterwizard replied to cybertron's topic in Electronic Projects Design/Ideas
Try Some of these Links! http://212.57.231.17/datasheetarchive/Datasheets/Zarlink_Semiconductor/DS111367.pdf http://w1.859.telia.com/~u85920178/tx/qrp-hf1.htm http://www.nrgkitsfm.com/workshop/early_stereo_5watt_pll_radio_jukebox.htm http://www.commlinx.com.au/rf.htm http://www.arrl.org/tis/info/qrpprojs.html -
Yes it is 2N278 TO-36 PNP GERMANIUM 15A 50V DELCO#5490810 hfe=50@1Amp
http://auctions.searchmarketing.com/default.aspx?semsearch=hpm+900&submit=Search
