steven
Members
  • Posts
    1,698
  • Joined
  • Last visited
Everything posted by steven
  1. :).thankyou for the reply audio guru , yesterday i tested a car battery charger as a power supply for extracting hydroxy gas from water and it dose ok , i need more current boost or output so im planing to try one of those current boosters at the outputs to increase gas production , so far the best one is the flyback driver circiut with the inductor near the input , the other flyback driver that has the black inductor i just threw it in to see what gives , and between the irfp450 n channell mosfet and the 2n3055 tranny i used in that same circiut when i made the modifications to use these trannys , i think the 2n3055 may have the edge after all
  2. :)the water is demineralized water and it has bi carb soda mixed in it to increase the conductivity enougth to start the electrolysis reaction , when i re played the video footage , and slowed it down the whole hydroxy gas generator jumped up about an inch and the flame i used to ignite it dident get blown out , thank you for the reply audio guru
  3. :)here is a picture i took off my pc monitor of my hydroxy gas test, i videoed it then played it on my pc then slowed it down and stoped it when the hydroxy gas ignited, i cant upload the video so this is the only way i can do it , the orange colourd pe pipe lite up yellow as if the yellow light from the hydroxy gas was penetrateing it like an x ray allso the white screw on cap to and the clear tube you can see the yellow flame , this made the hydroxy generator jump and the sound was like what sounds like a thud sound or something like a slilencer on a gun you see on movies
  4. :)ive just tried to upload a very short video clip i shot with my digital camera, of a hydroxy gas test, to here and its well under the maximin size allowed but it wont do it i get an error thing and its a mov that what it is but i dont know how to change it to post so it will post
  5. :)put an mov metal oxide varistor from drain to source on the mosfet , or you can try useing a transorb
  6. :)go to the high voltage stuff section look in topic separating hydrogen /oxygen from water , in there is a circiut for a pwm mini drill speed controller that i use for hydroxy gas makeing this circiut allso can be used for varying the brightness of a lamp
  7. :)look on the internet type bull horn circuit if its still there
  8. :) i would try useing a motor to turn a car ac alternator and with its biult in regulator use it to recharge a car battery then from the battery use a 12 to 240 volts invertor and from that ya have house hold ac power output
  9. :) its a 104 mono block can be used in place of ceramic
  10. very intresting in fact i once saw a movie on dvd some time ago called white niose and the man listens to it and he picks up vioce comunications through the white niose even on the tv i listen to white niose through my gravity wave detectors, which i posted in the forums here before , and ive allso been useing the expstudio audio editor to record them with, the studio audio editor can be downloaded free from the net, this has a range of filters you can use to filter what you receave through my gravity wave detectors and there is one signal that im waiting to record but so far its been comeing in when i havent got my gravity wave detector set up to the pc with the expstudio audio editor runing but while monitoring the white niose bband as i call it i have receaved an extra loud short bursts of white niose comeing over the low sounding white niose band a few times and find this very strange
  11. :)heres the latest of my flyback driver type hydroxy gas generator power supply that i modified to use a npn 2n3055 power transistor , remove the 100 ohms 1/2 watt resistor and re install the 300 ohms resistor , mine was a 300 ohms 1/2 waqtt resistor with a 1/4 watt size body, then remove the power tranny and this time instead of installing the small irf540 mosfet or 640 or 740, types use a large type irfp450 like in one of the other different flyback drivers i used before , the mosfet doent get hot like the 2n3055 tranny dose and it makes more bubbles and even more atomized vapours that i tested and it makes a small flame burn bigger and better , in fact the flame separated from the cigarrette lighter i used and nearly stayed alite for a few seconds longer , as if the vapours was keeping it going by itself for a short time
  12. :)thankyou for the input audio guru heres a picture of it in actrion even though its a mini drill motor controller it dose ok for a mini hydroxy gas generator , i had a 12 volts 1000 milliamps dc transformer so i used it and the heatsink got hot but it held up ok and i remeasured the voltage to make sure its what was said on the transformer but it was higher about 17 volts
  13. :)this last page came with the kit and may be handy
  14. :)heres the details for the 10 to 20 amp one
  15. :)heres another kit i put together and it handles 10 amps to 20 amps, if ya put in a second mosfet, but i just have one and somehow my small 12 volts lead acid cell batteries with there lower than car battery current, wouldent power this so untill i get it working i wont post the schematics yet
