4,138 -
Everything posted by ante
GreekPIC, You say,
A VERY usefull circuit , but how...
ante replied to nanopoylos's topic in Electronic Projects Design/Ideas
And here is another one: -
Nanopoylos, Here is something for the output: Ante ::) -
Connecting An Audio Output to 20 Headphones...
ante replied to Shahriar's topic in Electronic Projects Design/Ideas
Audioguru, On my Saab (50% GM) there is a thing called starter motor solenoid. This is a very big rely sitting directly on the body of the starter motor. The positive heavy gauge wire from the battery goes the this solenoid and another (not so heavy gauge wire) goes to the ignition key (between the front seats) carrying less then 1 A to control the solenoid (big rely) which carry 150 -
AJB2K3, The heatsink will lose some of its efficiency if you paint it. A heatsink is never painted just anodized for efficiency reasons so don
Harsh, No I have not tried it myself but it should work as far as I have seen from others. There can be a number of reasons why it did not work for you, sound card, operating system, other hardware or software on your computer. You did not describe what the problem was just
Rhonn, I didn
For prototyping almost every chip today comes in a standard socket as well as in smd so it
Audioguru, It works for me! Here it is in PDF. Ante ::) wiring_tech.pdf
Bikerman, It
Blacksheep, Maybe your input signal is to weak? Ante ::)
audioguru, I take a steady hand to solder these tiny legs. What link doesn
blacksheep, Here is all you need ! http://sound.westhost.com/projects.htm Ante ::)
John, Do they work with DC? Ante ::)
Trafo, Well we have to come up with something NEW then. I
Quantum, Have you checked the poles for any signs or manufacturers plate? If you can identify your
Darrin, I did not insinuate that you are lazy, that was your own words. ;D ;D Here is more for your E-Book shelf! Ante ::) More_on_OP-Amps.zip
Darrin, It
Greg, It
Hacker, Are you a collector of old computers? Were do you live? I can send it to you if you pay for the shipping. Ante ::)
Trafo, I
Rhonn, A high quality well maintained lead acid battery is not dangerous, but if it is not and it explodes the sharp edged plastic debris and the acid flying around is! http://www.msha.gov/Accident_Prevention/Tips/battery.htm Take Care ;D Ante ::)
Trafo, If you could remember a part of the name of the Siemens device maybe I could be found. Ante ::)
Trafo, I don
2SC867 TRANSISTOR SILICON [glow=red,2,300]NPN[/glow] / 400V / 1A / 23W / 8MHz 2SC 867A TRANSISTOR SILICON [glow=red,2,300]NPN[/glow] / 520V / 3A / 48W / 8MHz 2SC2827 TRANSISTOR SILICON [glow=red,2,300]NPN[/glow] / 400V / 6A / 50W / 20MHz 2SD326 TRANSISTOR SILICON [glow=red,2,300]NPN[/glow] / 250V / 1A / 17W / 6.5MHz
