EDY Posted July 24, 2003 Report Posted July 24, 2003 Hi Mike (and everyone else) :)First of all I have to say that site rocks :o 8) You Quote
mixos Posted July 27, 2003 Report Posted July 27, 2003 The IC3 = LM386 is a low voltage audio power amplifier. It's voltage gain can be adjusted between 20 and 200 with the external parts. So you can remove it and drive the speaker with your own audio amplifier. Quote
AVRFreakMan Posted August 1, 2003 Report Posted August 1, 2003 Hello EDY,you are correct. IC3 and its complementary componets are a just a sound amplifier and can be ommited. You can put the sound signal (taken from potensiometer's P1 wiper) directly into your's soundcard AUDIO input so that you can have totally digital control over your radio receiver.(You realise ofcourse that tuning isn't exactly 'digital' but looks like it :o) )The DOS software I have, is very old technology :( and has several bugs. If you want to look for something else, search for any freeware Parallel Port access tool on Google. You should find something...Kyriakos Quote
EDY Posted August 2, 2003 Author Report Posted August 2, 2003 Weel it says it can be connected to the PC on the schematics but that isn't my goal. Just want to build a simple fm reciver.Theres one thing bugging me.In my car's radio you can chose between low and high pass (not sure is this exactly the term) but I havent seen it on any schematics.I'll look the car radio later and tell you the frequencies it has.P.S. it has AM parto so don't think I'm talking about that :) Quote
AVRFreakMan Posted August 19, 2003 Report Posted August 19, 2003 Ok, you may use it as a simple analog radio receiver ;)About the other matter, the "low-high pass", I can only guess for what you are talking about. I think you mean "tone control" which suppress or raise the low-high frequencies of the acoustic bandwidth.Well this receiver doesn't have any of these 'whistles' because of it's simplicity. It is a mono (not stereo) FM receiver. Quote
EDY Posted August 19, 2003 Author Report Posted August 19, 2003 Actualy you havent guessed. Most probably becouse I made a stupid explaination of what I ment :(. I found the answer in one of philiphs FM radio chipsBut tanx anyway ;) Quote
Guest Wilson Posted November 22, 2003 Report Posted November 22, 2003 Hi,I build the FM Radio on a proto-board and I used a BB204B variable capacitor instead of BB329, but it didn't work. Anyone could tell me what modifications do I need to do in order to use the BB204B.Thanks for any comment!Wilson Quote
mayo Posted May 14, 2004 Report Posted May 14, 2004 Hi:Any has asembled this FM Radio with BB105 diode, I use this but dont work. Are shematic and components correct?(I hear noise but dont any radio).Thanks. Quote
AVRFreakMan Posted May 14, 2004 Report Posted May 14, 2004 If it cannot tune to any station, experiment with the coil. Stretch it, add more rounds... Quote
mayo Posted May 14, 2004 Report Posted May 14, 2004 Dear AVRFreakMan:Is correct, I cant tune any station. I will esperiment with coils.What coil define tunning frecuency? L1 o L2?If the radio is out of the comercial frecuency, How I can know if the radio is working and if the problem is only the coil?Anybody know the value of the coils (uHy - mHy) ?Thanks. Quote
AVRFreakMan Posted May 16, 2004 Report Posted May 16, 2004 L2 is the tuning coil.Just make it: take a thin wire(0,6mm) and make 5 turns of 4mm internal diameter.If it doesn't work try to stretch/squeeze it and if it doesn't work add/remove turns and repeat.(adding turns reduces frequency).If no success, check the PCB and components for errors, or use a capacitor trimmer instead of the varicap, or search the internet and the datasheets of TDA7000 for other similar circuits.Kyriakos Quote
ahmedhussain Posted July 28, 2005 Report Posted July 28, 2005 Hey,Please tell me the equivalent in MicroHenry [uH] of "5 Coils linked with internal diameter 4mm from cupreous isolated wire 0,6mm" of inductor used in thsi project.Also, please tell me that can we use the above inductor in equivalent Henry or we must have to make the inductor by ourselves.Also, please tell me the lenght in cm of the inductors used in this project.Thank you very muchAhmed[email protected] Quote
audioguru Posted July 28, 2005 Report Posted July 28, 2005 Hi Ahmed,Welcome to our forum. ;DThe IC hasn't been made for years. Where did you get one?The coil is simple to make, if you buy one then you won't be able to adjust it. Just make it and adjust it like explained above. Quote
ahmedhussain Posted July 28, 2005 Report Posted July 28, 2005 Sir i think u dint actually get my point. There are 2 types of inductors.1. That u make urself by using a wire of a certain lenght n thickness and making ciols of it.2. That u can get if u know the inductance of an inductor like 10uH, 0.1uH, etc. It looks just like a resistor. It does not have any coils.The function of both is the same. I tried both while i was making FM transmitter. But only 2nd one worked. So, I just wanted to know if it is necessary to use a handmade inductor or we can use the one that looks like a resistor ( I dont know what to call it )Thanks Quote
heathtech Posted July 28, 2005 Report Posted July 28, 2005 That u can get if u know the inductance of an inductor like 10uH, 0.1uH, etc. It looks just like a resistor. It does not have any coils.All inductors have coils, by definition. Quote
audioguru Posted July 28, 2005 Report Posted July 28, 2005 An inductor that you purchase is a coil of wire, almost like the one you can make. It is wrapped in plastic , tape or something so it can't be adjusted and its value is in color bands on it.A microwave inductor is a stripline, or piece of straight wire or rod and its inductance is determined by its length and thickness. Quote
anubhavbhardwaj Posted August 2, 2005 Report Posted August 2, 2005 i am an indian engineer.i want to know total description about fm. Quote
mr_popo Posted September 14, 2005 Report Posted September 14, 2005 i am a newbie here and i need help guys. i have a school project and i plan to include this fm circuit with iti am supposed to control the radio with my parallel port but the problem is i can't find the parts BB329 and BB105. any suggestion for a replacement for these parts? thanks in advance Quote
audioguru Posted September 14, 2005 Report Posted September 14, 2005 i am an indian engineer.i want to know total description about fm.www.howstuffworks.comwww.google.com Quote
audioguru Posted September 14, 2005 Report Posted September 14, 2005 Hi Mr. Popo,Welcome to our forum. ;DI can't find the parts BB329 and BB105. Any suggestion for a replacement for these parts?Like the project says, steal a varicap diode from an old TV tuner.Do you know where to get an old TDA7000 radio IC? It also hasn't been made for years. Quote
mr_popo Posted September 15, 2005 Report Posted September 15, 2005 thanks a lot. they still sell these ic's here in the philippines. good thing they have it. but in case these aren't available here, what can i use as a substitute? Quote
audioguru Posted September 15, 2005 Report Posted September 15, 2005 The new Philips FM radio ICs had tiny surface-mount packages and didn't have a tuning control. They scanned and stopped at the next station. They don't make the scanning ones any more, I guess because they were copied in China. They sell the new TDA7010 in a surface-mount package and it seems to be the same as the TDA7000.My wifey got a couple of the tiny scanning radios for free by signing-up for newspaper delivery. They sound terrible and the signal must be very strong or the sound fades and distorts. I thought the bad sound was from the cheap earphones, but they sound excellent on my Sony Walkman and CD player.I saw the radios at The Dollar Store selling for $2.00CAN complete with the earphones and two AAA battery cells. Oh yeah, the radios also have a cheap flashlight built-in. Quote
mr_popo Posted September 25, 2005 Report Posted September 25, 2005 i have a MV104 and MV1650 both varactor diodes , can i use these for replacement for BB329? Quote
audioguru Posted September 25, 2005 Report Posted September 25, 2005 Hi Mr. Popo,They are completely different.The BB329 has a wide tuning capacitance range of 12, the others only a little more than 2.I copied and pasted their datasheets from www.datasheetarchive.com . Quote
spynettz Posted January 18, 2006 Report Posted January 18, 2006 hello.. we tried doing the same project, there are hummings but no radio stations. we were not able to fine polyester.. we used mylar instead...,, is there any way it will work?pls e-mail me at: [email protected] for any suggestions..\thanks very much!! Quote
